Thread: '70 911S MFI - 009 Pump & Throttle Bodies, Stacks
    Nov 2002
    Fremont, CA
    Good rebuildable set of 2.2S Mechanical Fuel Injection (MFI) . 009 Factory Bosch pump, dated 5/70, still has some yellow paint on screws, good plating, pump pulley present.
    Throttle bodies and stacks, measure 35.8 or so mm at the base, factory 911S parts. 911 part numbers, so definitely 1970-1971. Air cleaner is included. Used cam pulley is included but not pictured.
    Fuel lines, crossbar, some linkages included. (Linkages will be supplied by your chosen rebuilder). All you'll need is a set of injectors and a pump mount plate for a complete system.
    $1750 obo
    Scott
    kindersport@gmail.com
    scott kinder
    Registry #614
    Nov 2002
    Fremont, CA
    few more photos..
    scott kinder
    Registry #614
    email sent
    Matt
    Mfi
    HI Scott,
    Your mailbox is full. I just mailed you check. Thanks.
    Matt
    Do I know that pump? Good stuff!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Replies: 3
    Last Post: 02-24-2014, 03:02 AM
  2. 72-73 2.4 911S & 73 Carrera RS MFI Throttle Bodies & Stacks
    Last Post: 08-19-2011, 08:22 PM
  3. FS: 911S MFI throttle bodies, stacks & pump
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 08-30-2010, 11:43 AM
  4. WTT '69S pump for 2.2 throttle bodies/stacks
    By Matt Blast in forum For Sale: 911 Parts
    Last Post: 06-25-2008, 02:29 AM
  5. 1969 911S MFI - mag stacks, throttle bodies and 001 pump
    By kenikh in forum For Sale: 911 Parts
    Last Post: 05-13-2008, 08:35 AM
