Thread: Drop links rear sway
    Are these adjustable drop links correct for my 71S? What kind of bushings should I use and do you have a link to a supplier that carries them. Cant find the same rubber ones that I removed from them. The drop links where attached to a ball on the rear suspension(bushing gone) and with a bolt(rubber bushing with metal tube in the middle(rubber cracked) to the sway bar. What end should go on the bar and what end to the suspension?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    drop link
    If its important, your pieces are not factory suspension pieces
    Jan 2006
    Naperville, IL
    John,
    Those are not OE; But I find them way cooler... ; You know vintage "back in the day" mods. It looks like OE front sway bar endlink bushings will fit those. I have some spare front bushings that I can measure for you if you measure your pieces.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Nov 2003
    Sydney
    John,
    These look like 'racer-adjustable-parts' to me though I am not a suspension expert.
    Check your parts manual or the PET cd to see what they look like as I think they should be a short one piece item with bushes of some sort.
    Suspension experts ??
    HTH
    Dennis.
    S Registry member 536
  1. Rear sway bar connection to drop link...
    By KenJ in forum Technical Info
    Last Post: 12-27-2013, 11:59 AM
  2. FS: 15mm Sway Bar w/Drop Links
    By Gray in forum For Sale: 911 Parts
    Last Post: 03-29-2013, 09:30 PM
  3. FS: SWB front sway bar drop links; Carb/MFI airbox connector
    By M_deJong in forum For Sale: 911 Parts
    Last Post: 02-20-2013, 10:29 AM
  4. FS: Rear sway bar drop links for an SC
    By EA911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-30-2009, 03:01 PM
  5. Rear Sway Bar Drop Link Question -
    By zcat3 in forum Technical Info
    Last Post: 09-28-2004, 11:00 AM
