Some from RR5. Cool VW logo on 550A trans case. Did a series on all the different number 'lighting styles from years past'
Steve Var.
_____________
61 356B
67S
66 912
66 Fulvia
72 914
Nope, the left is a '911 RSR' (BOSCH pn DV0460), right is just a 'street' injector we used for comparison (shows cross-section). The 'floating needle' design is the same used in the common 911 street fuel injector. Pretty cool needle assembly for the RSR!
Below are two photos showing the fuel spray pattern comparison.
I also wanted to mentioned even though both the RSR and 911 street injectors externally appear the same, the part number clearly identifies their internal mechanical differences.
The black ones are stainless steel under thin but sturdy conveyor belt rubber. The rubber is about 3/4 of a inch wider to act as a bumper in case of bumping a concrete parking block. I use a strip of the same rubber for the aluminum ones to protect the paint on the bunper.
Chris
9/16
I have added a middle section to it goes all the way across and made the splitter a little shorter.
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
The stubby-body fuel injector on the right in that photo is a "Mercedes" unit---that said, it is also the same internally as a 911 street fuel injector. The MB injector was used in the pix only to show the cross-section of the 'floating needle' design inside the injector compared to the RSR that's 'guided'. We didn't have a cross-section of the RSR to show. It was not the intention of my post to appear more on the technical side, but actually for the "Satanic Details" of the internal 'guided needle'.
PS: While on the subject... The 911 street injectors don't usually stick like the racing RSR injectors since those 'float'. The RSR injector, like a valve and guide in an engine head is 'guided' with a tight tolerance. When the fuel dries-up between the needle-guide and the needle, the RSR injector will stick. Truly a BPITA to get those parts cleaned and working again.
Thanks; learned something tonight. Appreciated.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe # 436
My SWB lazier cut spring plate fitted to 911SC adjustable pieces in black. With Rebel Racing bushings.
Chris
www.reSeeWorks.com
