Hi anyone know the answer to this one? I think one of the RSR's twin brake fluid reservoir's is a 356 one, but what about the other?
Any idea's, thanks Mike
cheers, Mike
Member#1664
1972 911 S/RSR to Martini Prototype specification
http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
Could it be from a BMW? 2002?
Early S Registry 1047
’15 VW GTI
'70 911E, Sold
'56 Cliff May Prefab
The one on the right is defently a 356 early 911 (65-67) the other looks like sixtys era mercedes.
Tony Proasi
52 split window coupe
I can't find any MB expansion tanks that look like this. The BMW 2000CS does look familiar.
2000CS used 2 distinct expansion tanks/fluid resevoirs.
01 EXPANSION TANK 1
34311100216 N/A ENDED (NLA)
02 EXPANSION TANK
34314650041 ($57.25)
Good hunting!
Tom
Early S Registry #235
rgruppe #111
Looks simular to what's on a MB 190 That I work on.......
Tony Proasi
Had no luck from the classic Mercedes and BMW experts, but have found out that they were made by ATE in Germany, so will try them. Thanks for the help.
cheers, Mike
Member#1664
I wonder if they were intended as clutch fluid resevoirs originally?
’15 VW GTI
'70 911E, Sold
What ever it came off of had a lot of fluid volume. It had to be either a big car or something that had big brakes. Also it had to be from a pre 1968 single circuit brake system.
Tony Proasi
Tom put me on the trail of the BMW 2000CS reservoir put hard to judge the comparative size. ATE in Germany put the phone down when I tried to speak to them in English today!
Here's the 2000CS version.
cheers, Mike
Member#1664
Mike
I have a NOS big reservoir, so its clean, and in my hand. I looked at it with a magnafying glass and I see min / max lines, the word ATE in big letters, under ATE is LOCKHEED, and under that is HYDRAULISCHE BREMSE no numbers or anything else. Does anyone know which set of brakes the big one supplies, front or back? I doubt this info will help much
Mike
