Big in front, little in back. Just like a good looking woman.
Best,
Tom
Best,
Tom
Early S Registry #235
rgruppe #111
Raj, that would be very kind of you, thank you.
cheers, Mike
Member#1664
1972 911 S/RSR to Martini Prototype specification
http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
Hi Raj, any chance of the diameter/circumference of the larger bottle?Originally Posted by varunan123
thanks.
cheers, Mike
Member#1664
Maybe this is it?? Towards the middle of the page
http://www.parts123.com/parts123/yb.dll?parta~partsort
Tony Proasi
52 split window coupe
Hi Tony, link not working, can you give it to me again!
thanks, Mike
cheers, Mike
Member#1664
Mike select brakes and the reservior is on that page.
http://www.parts123.com/parts123/yb....hPage~cadehfjC
Tony Proasi
Mike
The bottle is 9.75 inches in circumference. The top to bottom distance is harder to measure because of filler neck, and nipple. However the distance from the bottom ( excluding nipple ) to the top ( excluding the threaded opening ) is 3 3/8 inches.
here is a picture, i hope.
Nope. I got a error message, file to big. How do you cut these files down, its a JPG file?
Thanks Tony for that, but I think that's the smaller one, also used on the 356.Originally Posted by 911quest
It's the larger one I'm after, on the left of the picture that no one seems to be able to trace.
cheers, Mike
Member#1664
thanks so much for that, but is this the larger of the two bottles and do you mean 9.75 inches circumference, all the way round, as opposed to diameter?Originally Posted by gunzel
thanks again, Mike
cheers, Mike
Member#1664
