I debated the title; glad you looked!
The car isn't going to be a race car, just have a race car motor. It should come in just a little under factory weight. Not by much, though. Comfort will be as important as the "go fast" bits in this car.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Can you explain what these terms mean?
1. ovaled ports
2. offset ports
3. 'D'ed ports
Thanks?
Offset is more apparent on the intake. The bore was not centered in the old port to optimize airflow. The 'D' doesn't show well in the photos; the exhaust port is flatter and has a little dimpled area intruding into the port to direct airflow. The ports are not true ovals, they just aren't perfectly round.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
What are the 3 darker, dull gray spots around the valve guide?
Have the heads been tested to determine the optimum surface roughness as far as boundary layer turbulence is concerned? Smoother can give faster airflow but turbulence mixes the air and fuel more...
Beautiful work
Dull gray areas are the remaining surfaces of the original casting. I didn't want to pay to have them built up and remachined. Effect would be negligible. Extrudehoning was considered to condition the surface, but we were very happy with the heads after they were flow dynoed.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Kenikh-
You mention the four bearing cam carriers. Are you using four bearing cams, and if so, how is the pump drive handled?
Sounds like a great motor.
Anyone have any stock S port flow numbers handy?
Early S Registry 1047
’15 VW GTI
'70 911E, Sold
'56 Cliff May Prefab
What problems do you envision? I thought it was just a matter of popping out the cam carrier end cover.Originally Posted by Scott Clarke
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Kenik,
Which car is this going into?
Saw your early car out at Bernie's while dropping mine off. Very nice indeed.
Marc
'69 Coupe in Pastel Blau
R#464
S#1390
So you are fixing your car, eh, Marc? Cool. This motor is for the '69S. After dropping a valve in it, I figured I'd better hurry my ass up and get a motor built that isn't going to potentially cost me my 'S' case on failure.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Yes, finally. Bernie and I are going to discuss my options motor-wise tomorrow night at dinner. Are you going to make it this month? If so, bring one of those heads!Originally Posted by kenikh
Marc
R#464
S#1390
