Results 1 to 2 of 2
Thread: 67 brake lines
    old softie67S
    Feb 2007
    Sanibel Fl
    67 brake lines
    I am having some work done to detail the chassis of my 67S. The brake lines are going to be replaced. What is the general feeling on keeping the brakes the original single circuit or change to a dual circuit master for safety reasons while I am replacing all the lines?
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Mar 2006
    Louisville KY
    The dual circuit is safer choice but it you put a limited amount of miles on your car it isn't a real big deal. I would just make sure all of the hard lines are in good shape as they are the one's that usually fail. From water contamanation in the brake fluid they will rust from the inside out. The biggest change visually will be the brake fluid reservoir.
    Tony Proasi
    52 split window coupe
  1. Announcing 911 Brake Lines for SWB Cars
    By Neunelfer in forum General Info
    Last Post: 01-28-2013, 10:08 PM
  2. FS New set of rubber brake lines, SWB
    By fishman7 in forum For Sale: 911 Parts
    Last Post: 03-27-2011, 03:28 AM
  3. FS: lot of leftover hard brake lines
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 08-03-2009, 07:20 PM
  4. Stainless Brake Lines
    By larry47us in forum Technical Info
    Last Post: 01-11-2004, 07:44 PM
  5. Steel brake lines
    By kiwiporsches2 in forum Technical Info
    Last Post: 11-28-2000, 12:44 PM
