Thread: Weber white corrosion
    I suppose there is someone that knows how to stop the white corrosion that old Webers develop after they get wet. Richard Parr says there is no permanent fix, please say it isn't so!
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Are you just storing them or are you planning on using them?
    -Marco
    TLG Auto: Website
    weber white corrosion
    using them
    Paul Abbott
    Early S Member #18
    530.520.5816
    spray some Gibbs Brand on it
    Paul Schooley
    S Reg #863
    R Gruppe #330
    That would be called "bloom". It happens to aluminum parts that are exposed to the elements. Magnesium really breaks down. I believe Cornpanzer has some photos of a mag wheel that is all but gone.
    WD40 works fine. I use it to keep my BMW engine cases tidy.
    Best,
    Tom
    Early S Registry #235
    rgruppe #111
    The real issue is corrosion within the body and that it needs to be arrested. I think there is a chemical (intergranular?) issue that is at work here. I have removed the brass and lead plugs in the body in preparation for a dip process, perhaps a dilute muratic acid? I've already chased the internal passageways clear of this crud.
    Paul Abbott
    Early S Member #18
    530.520.5816
  1. corrosion
    By Cliff in forum Technical Info
    Last Post: 12-04-2010, 08:32 AM
  2. 69 911S Piston Corrosion
    By Brad Davis in forum Technical Info
    Last Post: 09-26-2010, 07:43 AM
  3. Front Hub Corrosion!
    By 304065 in forum Technical Info
    Last Post: 02-07-2010, 05:11 PM
  4. corrosion protection
    By John Fusco in forum General Info
    Last Post: 11-25-2004, 04:35 PM
  5. Corrosion Repair
    By heirplane in forum Technical Info
    Last Post: 02-12-2001, 04:09 PM
