Page 17 of 27 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 267
Thread: Show your Garage
  1. #161
    Oh, you mean warehouse spot does not count ? ;-)
    OK then:
    Before after 3 weekends' worth... Some drywall, some primer and paint, some racedeck, tried to hide the ugly ramps.. Work in progress...
    Rotating in there between the 911, alfa and Bimmer.
    Greg.
    72 911T - 73 2002
    #1461
  2. #162
    Quote Originally Posted by boba View Post
    Yes, I am. 3 ton heat pump with heat strip in the air handler for those few times we get below 15 degrees.
    Bob,
    With those high ceilings your registers should be lower to increase efficiency. If the registers are in that duct, you'll have a hard time keeping the lower work area cool. In the winter the warm air will stay on top. It's always a compromise, but in our climate, its better to weight towards the long summer season.
    What is on top of the roof? Is it just steel?
  3. #163
    I am a fan of exposed ductwork. The industrial look works well aesthetically. They are far more easy to build and get the conditioned air where it's needed. It's a garage!😉
    Early S Registry #235
    rgruppe #111
  4. #164
    Senior Member boba's Avatar
    Jul 2006
    DFW
    David, it is a metal roof which has sprayed on foam insulation and then the insulating batting you can see. The walls also have the foam and batting. The garage door is insulated as well. My unit is East facing so I get morning sun. My unit has other units on three sides, which have AC/heat. I have a 12' Big Ass fan to move air as well. I'm not trying to keep it cool in summer just keep it from getting too hot in there. I should know soon enough if it's going to be comfortable, if not work will have to be suppended and cool beverages consumed.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
  5. #165
    Jul 2006
    DFW
    I do like the way it turned out.
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    08 GT3 Speed Yellow
  6. #166
    Senior Member Christian Guthrie's Avatar
    Jun 2011
    Arizona
    Quote Originally Posted by Varooom View Post
    I want this... The new (old) way to store your stuff at some comparible rent than a 'traditional garage'... Not really for rich guys anymore...
    No Piper Cub needed....
    Most airports are restricting hangar space to aircraft only. The surrounding airports in the Phoenix area all have strict "airplane only" rules which also extend to couches, refrigerators and mini bars as well as cars and motorcycles. I have a bunch of friends now looking for car storage for their Porsche's and a new place to hang out.
  7. #167
    Jan 2011
    Boulder, Co
    Quote Originally Posted by Christian Guthrie View Post
    Same issue in Colorado. I looked for hangar space but was rejected due to airport security.
    LOOKING FOR:
    ENGINE Nos: 4080191, 911669
    GEARBOX Nos: 9282004, 131410, 115639
    1967 Porsche 911 P.A.R.T. Trans Am Rally Kit #308107
    1968 Porsche 911S Sebring GT class winner #11800224
    1971 Porsche 911S Targa Conda Green
    1973 Porsche 2.8 RSR ex-Targa Florio, 2xLeMans #9113600894
  8. #168
    Jul 2006
    DFW
    Staging the dealer sign for spacing and fab of hangers.
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    08 GT3 Speed Yellow
  9. #169
    Jun 2011
    Mound, Louisiana
    I am good with it!!!
    I just scrolled through all pages of this thread.. Epic is what I would call it. Feeling kind of small, but so proud to be in the group!!!
    And proud that mine is not only under cover, but climate controlled as well!
    Paul Harrop 12.5% German.
    Early S #2059
  10. #170
    Senior Member Varooom's Avatar
    Oct 2006
    SoCal
    Quote Originally Posted by doigthom View Post
    Steve. Realize you may be fantasizing, but you might want to look into these guys. http://www.performancegarageclub.com/storage/. No affiliation yet but possibly going to store my 912 there when engine is finished. From NYc you go out through Holland Tunnel onto 78. Then down 31 to Flemington circle and out 12 from there.
    I have a space already I am working on.. ( on LI /NY) My stuff is in and almost ready for NY gatherings....
    Steve Var.
    _____________
    61 356B
    67S
    66 912
    66 Fulvia
    72 914
  1. Garage find in our own garage versuch swt
    By Bivvv in forum General Info
    Last Post: 12-22-2021, 05:57 AM
  2. Show Your Garage
    Last Post: 11-09-2020, 06:48 AM
  3. Replies: 2
    Last Post: 02-09-2014, 10:53 AM
  4. Replies: 38
