Thread: Pic request: plastic window pulls
    hi all
    does anyone have any pics of the strap arrangement used to raise/lower plastic/lexan windows in 911R's, ST's, RSR's etc.
    from what i can gather the strap attaches to the bottom edge of the window (inside the door) but i'm a little unclear on the fitting that the strap connects to on the door. i assume that a small hook is used which passes through holes in the strap to set the window position.
    any other tips or tricks in making and/or installing these would be great appreciated.
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Here's a tip:
    The leather will streatch over time, so make sure that you allow for that and punch the holes so that, initially, they hold the window a little tighter than you would normally like. In about 6-9 months the leather will stretch and the tension will release and everything will be hunky dory. Otherwise, you'll have sagging windows that don't close all the way.
    -Marco
    TLG Auto: Website
    Raj - thanks, would you have a close up shot of the hook?
    Marco - thanks for the tip.
    Cheers, Ryan
    Aug 2006
    Chicago area
    Quote Originally Posted by Mr9146
    Here's a tip:
    Yep, just like mine. That's why you see little wood blocks in the R door panels - to prop up the window. These are special rare factory wood blocks, you know, that go inbetween the strap and window sill.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    raj
    thanks for the follow up. we ended going for a slightly different (and i think safer) solution:
    http://www.early911sregistry.org/for...ad.php?t=23729
    Cheers, Ryan
  1. 1968 Fixed Window Targa glass photo request
    By Max (SD) in forum General Info
    Last Post: 03-11-2013, 06:52 PM
  2. FS: Plastic window set, 7 pieces
    By javadog in forum For Sale: 911 Parts
    Last Post: 08-07-2012, 11:29 AM
  3. Replies: 8
    Last Post: 06-30-2011, 11:03 PM
  4. WTB: SWB earlier hard plastic flattop door lock pulls
    By gtgroupe3 in forum For Sale: 911 Parts
    Last Post: 08-27-2007, 05:58 AM
  5. Plastic window question
    By obrut in forum Technical Info
    Last Post: 02-26-2007, 07:15 AM
