Page 10 of 144 FirstFirst ... 891011122060110 ... LastLast
Results 91 to 100 of 1437
  1. #91
    Oct 2008
    Burford, ON, Canada
    Thanks Lee. Any transmission # and paint code for 302340?
  2. #92
    Senior Member 302340's Avatar
    Feb 2008
    Milwaukee, WI, USA
    Transmission Number
    Hi Dave,
    The transmission in my car is not original, though I should look up the number just so it is on record. I'll try to get it for you. The original color of my '66 is Sand Beige; I'd have to look up the number (6601?). It was Sand Beige, then painted blue, then red, and will become beige again when I have it repainted. If there are any other details you would like to know, just ask.
    Lee
    302340
  3. #93
    Oct 2008
    Burford, ON, Canada
    Sand Beige = 6607 Thanks for the info. Every little bit helps.
  4. #94
    Feb 2008
    Milwaukee, WI, USA
    302340 Transmission Numbers
    Hi Dave,
    The numbers for the transmission in my '66 are:
    Type: 902/02
    Number: 12801009
    Lee
  5. #95
    Feb 2008
    Milwaukee, WI, USA
    '65 Information
    Hi Dave,
    Please add this to the production list. Verified by CoA:
    VIN: 300595
    Production Date: 03/04/1965
    Engine Number: 900702
    Transmission #: 100620 (901/0)
    Paint Code: 6407 (Signal Red)
    Lee
    302340
  6. #96
    Oct 2008
    Burford, ON, Canada
    Thank you.
  7. #97
    on ebay
    901/01 - 900718 - 618
    Glenn Stazak
  8. #98
    This is chassis #305772, engine serial #909416, build #5645.
  9. #99
    Hi Dave.
    One of the pairings you already have on your list is:
    901/10 18358
    6390486
    Is there a high probability that it is original for VIN 119310130 ?
    It seems pretty close based on the relative postion.
    Is there any data that would indicate the trans serial number?
    Thanks, Bill
    Bill
    1969 911T - sold
    2001 911 Turbo - sold
    1996 911 C4S - returned
    1982 911SC - gone
    1960 356 Roadster - sold
  10. #100
    Oct 2008
    Burford, ON, Canada
    That is the VIN I have for the engine serial #, and it seems to be a reasonable fit. VIN is from an eBay auction. Are you the new owner? As far as the trans #, I have no data since they are not as easy to get. I certainly can use much more data to make the database more useful as a predictor.
  1. Martini RSR engine build
  5. Engine build
