Page 75 of 144 FirstFirst ... 2565737475767785125 ... LastLast
Results 741 to 750 of 1437
  1. #741
    Feb 2012
    Netherlands, Leiden
    1968 911T (sporto?)
    2180032
    901/13
    10472
  2. #742
    Oct 2008
    Burford, ON, Canada
    Thanks for that one. Just updated the first two posts with latest data.
  3. #743
    Feb 2012
    Netherlands, Leiden
    3280140
    901/14
    9915
  4. #744
    Feb 2012
    Netherlands, Leiden
    911 E carter 1969
    901/11
    25642
    6298559
    https://www.marktplaats.nl/a/auto-on...e-carters.html
  5. #745
    Nov 2017
    Victory
    I have engine number 903850, type 901/ build 3766, This motor was converted to Webers and I wonder should it have had center lube cams?
    My car is chassis number 303165, it should have engine number 903272
  6. #746
    Nov 2017
    Victory
    I have two dismantled engines, one I believe is a 66 built 1967 911 normal, the other a 911L 901/14
Size:  76.4 KBName:  IMG_2337.jpg
Size:  88.0 KB[Name:  IMG_2338.jpg
Size:  118.7 KBATTACH=CONFIG]441967[/ATTACH]
  7. #747
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by Kismet View Post
    My car is chassis number 303165, going by the numbers you have listed I think my car should have an engine around number 903241, is that correct?
    I would say between 903200 and 903400 since the serials jump around a lot. The only way to get the original engine # now is to obtain the Kardex, and that I can help you get. That build # splits up a group of six 906 engines. Please tell us more about 303165 in it's own thread.
  8. #748
    Oct 2008
    Burford, ON, Canada
    901/06 911607 8227 dated 66/12 , yeah, only 11 large dots, but no room for the twelfth which appears to be smaller and inside
    901/14 3280151 9933
    Many thanks for these three engines. I could do with date marks on both case halves on any cases +/- six months of this one since I have little data. Also look for the mating #'s stamped on the top of the case, and the casting part #'s on the lower sides of each half please.
  9. #749
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    901/02 4080127 9451
    901/01 903124 3024
  10. #750
    Feb 2012
    Netherlands, Leiden
    Dave, got a '68 901/03 for you:
    901/03
    12933
    2080824
  1. Martini RSR engine build
  5. Engine build
