Page 8 of 144 FirstFirst ... 6789101858108 ... LastLast
Results 71 to 80 of 1437
  1. #71
    Member steven71's Avatar
    Dec 2005
    Luxembourg / Europe
    Hello,
    Here is mine:
    Vin 307955 S (european french S from 1967)
    901/02 8183
    *961611*
    Best regards
    Steve (Luxembourg/Europe)
    1993 964 C2 convertible
    1967 911 S
  2. #72
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    901 xxxx
    . The engine number is 902586. Casting numbers on each side of the case are 90110110201 and 90110110101. Both sides of the case are stamped 950. The case is date stamped 6/65. The engine type is 901/01. This case has been inspected by a machine shop and appears to have no visual defects and is in tolerance for a 40 year old Porsche engine case. Stock#041309.
    eBay #380124537470 it just happens to be for sale,not mine,for reference only for this thread.........Cliff
  3. #73
    I have another alu for you
    328027
    901/14
    10744
    Richard
  4. #74
    Oct 2008
    Burford, ON, Canada
    Thanks again guys. Richard, that one sems to be missing the last digit 328027x
    I also have your name down against 901/06 3080xxx 10743 that just so happens to be the preceeding build #.
  5. #75
    Apologies Dave. It's
    3280327
    It's a really coincidence that I came across two sequential engines.
    From 3280327 I will get you the case matching number later. Currently it's covered by the fan shroud.
    Richard
  6. #76
    Dave here is one more:
    Chassis #: 308451S
    Engine #: 961107
    Transmission #: 229306
    Paint Code: 6001 – Signal Green
    found here:
    http://klubsportracing.com/index.php...mart&Itemid=46
  7. #77
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by 304678 View Post
    Sure it is!
    See if you can get the serial # for the other engine too, please.
    I appreciate all pairing #'s when it is possible to see them.
    It is also nice to get the casting dates from the block.
    For the aluminum case engines, this set of 5 numbers can be really useful. For the magnesium engines, the sixth number to collect would be the left & right case part # end digits (like the 7R case, however in some cases one might find a 5R & 7R type of matching).
  8. #78
    Dave
    I saw this one on eBay
    961521
    901/02
    8009
    http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1179
    Richard
  9. #79
    Restoration newbie.
    Jun 2007
    San Francisco
    Dave you already have my numbers 901/02 961687 8316
    so I'll just add my pairing number 311.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  10. #80
    Oct 2008
    Burford, ON, Canada
    Thanks Richard. Thanks Andy. Can we get casting dates from as many engines as possible please.
    I added a couple as well. That give us a total of 192 build #s so far.
  1. Martini RSR engine build
  5. Engine build
