Thread: Chrome to Powder Coat
    Hi Guys,
    I have a set of chromed steel wheels that I had stripped by a chrome shop and then powder coated silver. The wheels came out with a yellow tint in the silver powder coating. Looks like varnish. The powder coater is going to strip them again and redo the wheels.
    Any idea what would cause this problem? Maybe the copper base coat from the chrome? Should the wheels be baked to release contaminents left over from the chrome?
    Brad
    Wrong color?
    Paint pigments usually don't mix with the base material unless it's a translucent paint.
    With regular car finishes, paint layers can bleed through if the materials aren't chemically compatible (e.g. lacquer vs. enamel). A sealer is then applied pn top of one in order to separate the mismatched chemicals.
    Sherwood
    Hi Sherwood,
    Thanks for the reply.
    The wheels are going back to the painted steel wheel look. They are silver powder coat with a powder coat clear on top. I am not sure if they shoot both colors then bake or if it is a two step process.
    The yellow tint does look like that of an old clear coat that is yellowing.
    Brad
    Brad,
    I'm not that up on the intricacies of powder coating, but the powder, having been electrically changed (+ and _) with the base metal respectively, melts at high temperature and fuses onto the metal.
    In other words, can a second layer of powder (clear) be applied on top of a previously applied coating of powder? The reason why I ask is that typical enamel and lacquer clear coats, when sprayed, typically turn yellowish and maybe that's what you're experiencing. Check with your vendor.
    Sherwood
  1. FS: 1971-1972 Rear Trailing arms. Refinished in powder coat - $500
    By bdstone914 in forum For Sale: 911 Parts
    Last Post: 12-15-2013, 02:41 PM
  2. FS: Engine Tin & Muffler Mount Fresh From Powder Coat
    By 76911S in forum For Sale: 911 Parts
    Last Post: 12-22-2012, 11:30 AM
  3. Powder Coat a Trombone Cooler?
    By kentf14 in forum Technical Info
    Last Post: 11-15-2012, 03:50 PM
  4. Replies: 5
    Last Post: 10-01-2012, 01:11 PM
  5. Coat Hooks
    By joetiii in forum General Info
    Last Post: 04-23-2007, 05:18 PM
