What would be the most correct/best case to use for this engine build. With the 66 crank, what cyl/pist would you use and would the case have to be modified to take the cylinders? Would you shuffle pin the case?
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
John, this question had a Norwegian bent to it, but you may have seen it already. From Pelican
http://forums.pelicanparts.com/showthread.php?t=436892
and this thread that Henry @ Supertec referenced
http://forums.pelicanparts.com/showthread.php?t=434823
I believe Curt has a 2.5 so he may be able to advise. Or someone else who has already done it.
'72T Coupe - Sepia Brown
Thank you for the link Karlusmagnus!
i am also looking at building a s/t 2.5ltr but a long stroke using a 2.4t engine as a starter .
If some s/t 's used mfi and some didn't , what carbs set up did the ones with out mfi use?
John Gausden
Auckland, New Zealand
(shipping carson,CA)
Early911nz.org
ST-Classic.com
ST-Classic Facebook
here it is
http://www.early911sregistry.org/for...368#post183368
Karl.
hello raj,
You couldn't scan that spec sheet and flick it through on the email ?
advtracing@gmail.com
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
FWIW,....There are still a few Mahle 89mm P/C sets (Nikasil) made for the IMSA 2.5 litre GTU motors w/66mm cranks still available. These have 97mm spigots so the cases need to be bored to use them.
Let me know if I can help.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
2.5s are for pussies. Go with the ORIGINAL ST motor, an 85x66, 2.3L big cammed beast of a motor that made 250 HP at 7800RPM.
http://books.google.com/books?id=QJV...i8Bg#PPA109,M1
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Does anyone still stock the Mahle 86.7mm pistons & cylinders for the longstroke 2.5 motors?
Somewhere around 10.3 or 10.5 compression?
If available are they Nikasil?
Or are JE / Nickies the only way to go?
Looking for engine # 6208151
'74 RS 3.0 Replica
'70 911E Bahia Red (SOLD)
'71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
Australian TYP 901 Register #78
Early S Registry # 1076
Try this Cam.......
http://www.andial.com/content/mahle/newlatermodel.htm
Cheers mate
