Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Factory Original Chassis Werks Car Modification
  1. #11
    Registered User parced@telia.co's Avatar
    Apr 2005
    Rs 3.0 1974
    This is a little later car so I might be sliding of topic.
    This is 9062 RS. This car was born as a RSR but had a major crash late in it´s life so it was decided to change tub, at the factory in 75, and remake it to a street car and therefore a RS 3.0. It got a new engine. The chassi has these reinforcements.
    Inside the car it looks standard and not lite the next picture that is from a 73 RS. I have not seen any other 74 RS so I do not know if the factory took a shortcut or if that was a change on the 74.
  2. #12
    New(ish) in the box.
    Tom
    Early S Registry #235
    rgruppe #111
  3. #13
    The shock-tower re-enforcements I've seen before . . .
    . . . but this little gusset, I've not
    Only here
    Does this work?
    The fia are now making you remove the shock tower braces/webbing for 73 rsr papers.
  5. #15
    Why is that? were they not homoligated?
  6. #16
    No not homologated,i can find no info that says it was any where.
    The fia papers have to be redone every 5 years now,and new papers go into much more detail and photos now.even the height/placement of the duck tail is now checked.
  7. #17
    Oct 2010
    Florida
    Where did you locate the current FIA papers?
    Richard Newton
  8. #18
    Wasn't that bracing added when they went to supplemental springs? Maybe beginning in 74?
  9. #19
    You can get the current paper forms off the fia www.
    Springs were used as early as may 73,but no homoligated web reinforcement can be found so far.
    In 74'they used reinforced larger turrets for the coil over dampers.
  10. #20
    Targa Reenforcements . . .
    . . . another thread --- see post #18 . . .
    http://www.early911sregistry.org/for...-Germany/page2
  1. Factory Chassis Dolly
    By RS#007 in forum General Info
    Last Post: 08-23-2017, 08:52 AM
  2. Original 73 front chassis paint (I think)
    By Mark Wilson in forum Technical Info
    Last Post: 01-21-2014, 10:22 AM
  3. W: original RS Chassis
    By po356 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-28-2013, 01:25 PM
  4. W: original RS Chassis
    By po356 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 12-28-2013, 06:33 AM
  5. ID the 1972 factory chassis stamped.
    By Ramany in forum General Info
    Last Post: 07-26-2009, 10:01 PM
