Thread: No undercoating ? I need feedback...
    Feb 2005
    Montreal, Canada
    Hi,
    I'm almost done removing all the undecoating on my 72 ; My original plan was to put a thin layer back before the tangerine paint all under the body. But I came across M.Butler signal orange RSR replica in an old excellence mag and the clean-smooth finish under the the car is awesome !
    Does someone drive a car without undercoating for sometime and can tell me how it looks after thousands miles ?
    My car will be a weekend driver (5-6 months/ year : in our nice Northern weather...)
    Thanks !
    JD
    The only issue I've seen is getting your tires hot enough that they fling rocks at the fenders leaving "outies".
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Senior Member drwhosc's Avatar
    Dec 2007
    Spartanburg SC
    Check out a product called quite car www.quitecout.com. I used it on my restro. It worked well, looks like the real deal, and provides the protection you will want. The sprayer you can get with this product gives you the nice stippled look. It goes on black, but you can paint over it with good results.
    71 911E RS Clone (Analog)
    88 928 S4 (V8 Trans Axle)
    99 996 (Daily Beater)
    Early S Registry # 1278
    Leave it bare and wear earplugs
    Stuart Zeh
    sezme@aol.com
    Dec 2007
    Spartanburg SC
    Quote Originally Posted by sithot View Post
    Thanks for fixing my link. Still learning to type on the iPhone
  1. Painting or undercoating or not?
    By Soterik in forum Technical Info
    Last Post: 04-21-2010, 04:28 PM
  2. undercoating ?
    By robmog in forum Technical Info
    Last Post: 07-20-2009, 05:15 PM
  3. Undercoating?
    By jasam in forum General Info
    Last Post: 05-14-2008, 09:02 PM
  4. What To Use For Undercoating?
    By FHernand in forum General Info
    Last Post: 12-13-2006, 07:04 AM
  5. undercoating and carburation
    By snowbound in forum Technical Info
    Last Post: 02-11-2003, 04:41 PM
