Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: 911rs #266
  1. #21
    Raj,
    Thats very interesting as my 73S certainly had a black tash top not removing the dash on the RS to check however except to say where the dash wraps around at the sides is black also but in the pic of your ST colour would be visible I believe.
    No cutting just careful peeling back where the glue was a bit loose anyway.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  2. #22
    Very similar to the RS Raj, more black on the centre tunnel than Frank currently has as same on sides.
    Clyde Boyer
  3. #23
    The Netherlands
    dash top
    All matt black dash top on my, last series, RS, black around fresh air vent is from a later date..
    Cees
  4. #24
    Yes not sure Raj but I wondered why there is so much paint under the handbrake area which is totally covered by the handbrake, carpet and the handbrake rubber boot
    Clyde Boyer
  5. #25
    911rs #266
    Hi Raj, those oil lines appear to rubber hose, not the brass lines we normally see, is this true?
  6. #26
    911rs #266
    Ouch!! the race and rally cars sure had a hard life!
  7. #27
    Frank,
    In the course of figuring out what to do with my 72S, I looked carefully at an original late model RS (1400's) and took the following pictures:
    Attachment 62579
    Attachment 62580
    Attachment 62581
    Attachment 62582
    Attachment 62583
    Since the your car is a first series car it may have the same characteristics as Clyde's car with respect to the mats.
    My theory on this: Weren't the early cars first built as Lightweights (i.e. no sound deadening etc.), then weighed and homologated, and then converted to Touring spec? If so, the car could have been built without mats, sprayed body color, and then after homologation the mats would have been put in on top of the body color.
    Hope this helps.
    Best, Guru
    Guru Sivaraman
    1972 S
    1977 3.0 Carrera
    Early S Reg. #1199
  8. #28
    9113600266
    VIN = 9113600266
    Eng# = 6630273
    Trans# = 7830270
    Prod# = ?
    Another thread . . .
    http://www.early911sregistry.org/for...-auction-today
    Senior Member patrick911's Avatar
    Mar 2007
    Melbourne, AUS
    Reviving an old thread.
    My RSR replica is being painted as we speak, and I'm still wondering what to do with the footwell/area under the dash?
    Unfortunately Raj' pictures and posts are removed so I'm wondering what the Martini RSR would have had. Full black dash top to bottom, or only the actual dash?
    Reading through this topic, it sounds as if the RS sport & RSRs had black all the way to the floor with a bit of overspray, all to prevent the original color coming through where the mats meets.
    However, I've seen photos of R7 (the sister Martini car) taken in the 80s or 90s where the full footwell seems white. And it's all that dirty and damaged that I'm convinced it is original.
    The museum car is of no use as a reference, as that was a 1972 car originally so different in quite a few respects (black engine bay & frunk for one).
    Then I've also seen pictures of the Brumos restoration (RSR 0328), where they kept everything except the actual dash white.
    Who can tell me what's correct on a factory raced 1973 RSR?
    Member #3508
    1973 911 2.4T
    1976 911S -> 2.8RSR replica
    "if nothing goes right, go left!"
  1. From 911RS to 911ST
    By Mr9146 in forum General Info
    Last Post: 05-15-2017, 10:04 AM
  2. FS: '74 porsche 911RS 3.0
    By kaufmanp in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 07-19-2013, 06:28 AM
  3. NOS 911RS MFI ump
    By pu911rsr in forum For Sale: 911 Parts
    Last Post: 09-15-2012, 06:00 AM
  4. Wtb: 911rs
    By Carparc in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 11-15-2010, 11:29 AM
  5. 3 generations of 911RS
    By nickd in forum General Info
    Last Post: 03-26-2010, 06:23 PM
