Results 1 to 10 of 12
Thread: Need engine harness wire routing help!
    Need SWB engine harness wire routing help!
    I've redone the rear wheelwells and everything behind the rear floorpan seam in my '68, and I am tidying up the 42 year old wiring.....most of it seems straightforward, but I have one question:
    For the oil pressure and oil temp green wires, do they branch off at the starter and go up the gap into the engine bay on the right hand side, or do they follow the rest of the main wiring harness into the left hand side of the engine bay and route around that way?
    Thanks for any help!!!
    Come on someone has to have some input here!!
    Senior Member 68911USA's Avatar
    Jan 2009
    Salisbury, MD
    I just looked at my '68, and the oil pressure wire goes towards the left side, as does the oil temp switch. Hope that helps!
    1968 Porsche 911 #11830133 (2009- 2012)
    1968 Porsche 911T #11820522 (1997-2007)
    Registry Member #1536
    Hagerty Insurance Guy
    Missing my Porsche. Need to find another SWB project!
    Current cars:
    1918 Willys-Overland Model 90BT
    1966 Sunbeam Tiger Mk1a
    1977 Chevrolet Suburban C20 "Trailering Special"
    1983 Ferrari 308 GTS Quattrovalvole
    1992 RHD Toyota Century
    The 66 I'm restoring has the oil pressure wire branching off the harness in the middle of the shock crossmember. The oil temp wire continues on around the left side and across the rear of the engine compartment to oil temp sender.
    Ed to the rescue again! What you say makes perfect logical sense, that is what I will do with mine! Thanks!
    By the way Fritter, I remember your picture of the rear wiring you're in the middle of, McMaster Carr has the 1" I.D. vinyl sleeving that will replace the original that you are probably missing. I just used some on a 66.
    Can't wait to see the pictures!
    Peter Kane
    '72 911S Targa
    Wow, thanks for the tip Ed! Where does that sleeve end, where the wiring goes past the shock crossmember into the engine bay?
    Fritter, here are some pictures of the sheathing and the routing, it comes up by the left shock mounting.
    Senior Member Carparc's Avatar
    Costa Mesa / Long Beach CA USA
    Hi, would you by chance have the part # from McMaster Carr of the 1" I.D. vinyl sleeving?
    Thanks, Henk.
  1. More wire routing ?? (the rear this time, '67)
    Last Post: 11-22-2013, 09:58 AM
  2. Wire Routing Carried to the Extreme
    By sithot in forum Other Car Cultures
    Last Post: 11-05-2013, 05:07 AM
  3. Wire Routing Carried to the Extreme
    By sithot in forum Technical Info
  4. Wire harness routing question (1967)
    Last Post: 09-18-2013, 04:03 PM
  5. engine electrical harness, wire & connector identities
    By mcaterino in forum Technical Info
    Last Post: 06-23-2010, 06:47 PM
