For a numbers matching '73 RS going into a restoration, I'd appreciate hearing opinions about the benefits and risks of building the engine as a 2.9L instead of 2.7L. Opinions about changes to it's "originality" also welcomed. Thanks.
Originality aside, the magnesium cases really get stressed with larger displacement. You could probably achieve almost the same power by raising the compression to 9.5.
i heard too many stories about 2.9's failing - although it is hard to separate fact from fiction.
if you want to go a little bigger, a 2.8 is much more battle proven, and has the 2.8RSR cachet to boot.
Cheers, Ryan
Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
I would leave the 2.7 ALONE. IF you want more power/displacement/etc., build a new engine, put it in the car, and put the original 2.7 on a stand somewhere.
Bahia Red '72 911S
Meerblau PTS 2019 Speedster
ES #333
Don't do a 2.9L. This is the definition of pushing your luck. You might get lucky, but why try?
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Don't do it.
Randy Wells
www.randywells.com/blog
www.hotrodfilms.com
Early S Registry #187
Donīt go over 90 mm on a mag case, these days even 90 mm is on the bigger side. There is a big risk that you will be sorry when you are taking the engine apart, not many cases has survived without cracks. A friend looked at 10 used 07R cases and all had cracks! He then rebuild his original 73 RS engine around a sandcast 65 case. I'm rebuilding my 911/83 around a sandcast 65 case as well, stretching it though. I had a 95 mm RSR P/C set, it's the 2.8 upgrade set, and I thought it could make a fun engine.
2.9's have issues and those 93mm P/C's are not known for longevity & durability.
The biggest I'd go is a 2.8 and they run VERY well if properly done,...
Keep the revs reasonable and they last a long time.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
