Results 1 to 10 of 10
Thread: Please provide info on 1968 options
    Dec 2004
    SE Michigan
    Looking for information on the following options including option codes, how they would have been provided (for example, factory only or dealer). I am using my '68 as a daily driver since February (including winter ) and these are some options I'd like to add as I think they would be handy:
    1) rear wiper (code #425)
    2) rear defog (code #436, years available?, see: as a '67 option)
    3) Hella 118's (code #432)
    4) rear engine lid light
    5) motometer gauge (I have one, and an S member has offered to provide pics of his factory installed gauge, wiring, etc.)
    6) hood lights
    7) webasto heater
    Any pictures, info, installation tips, direction to helpful threads...whatever...would be greatly appreciated.
    Gas heater would be nice, but I have assumed it would add a significant fire risk, no?
    BTW, I don't understand why Bruce Anderson has said that the SWB are not suitable for daily use. I suppose I'm not in LA traffic, but I do drive about 35 miles round trip to work, take my 3 boys to baseball, errands, etc.
    Bill G.
    EarlyS #718 | RGruppe #437
    Daily Driver
    Thats great
    I would love to have a 68 Sporto with AC for a daily driver.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Hi, this link usually gives option codes but doesn`t seem to be working.
    http://www.kindel.com/porsche/options.asp
    This one helps with a few,
    http://www.911t.org/options/
    Regards, Mike.
    Nov 2003
    Sydney
    Bill,
    All the others will be correct for the '68 MY but the rear screen de fogger which started in '69 MY.
    You should have two triangular heater vents in the lower corners of the rear screen - fairly useless imho as well as not very safe.
    If you want a better rear screen heater you may want to advertise in the wanted section of this board - there are two different ones from '69 onward.
    The earliest has only the centre half the screen wired and later screens were full length.
    Make sure you get all the wiring etc.
    There were aftermarket kits available but they have probably gone the way of unrestricted speed limits in the early '70s.
    Great to see another early 911 being used daily as it was intended to be !
    HTH,
    Dennis.
    S Registry member 536
    You may want to find the factory part # for Ziebart rust proofing
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Dec 2004
    SE Michigan
    Quote Originally Posted by Cornpanzer View Post
    The "funny" thing is that this car was Ziebart'ed. They drilled holes in the door striker plate panels...there's no cavity there to treat. I have been inspecting all the undercoating for cracks and have started spot treating areas. This fall I will be taking the '68 to a place in Windsor that applies rust proofing to the exterior (krown.com). In a few years, I'll repair, restore, repaint. For now, what's the difference between a 1/4 inch rust spot and a 1/2 inch rust spot? How many people can say they've driven a SWB year round through all seasons...really no one anymore. It's worth the experience. Trust me, you'd love it. Driving a SWB in the snow is exhilarating.
    Bill G.
    Quote Originally Posted by gulf908 View Post
    Bill,
    Dennis.
    There was option code 9484: Heated rear window. Would this be the heater vents only? Or were those standard, and if so, what then is 9484?
    Henry
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    Quote Originally Posted by 911scfanatic View Post
    So is getting one started at -10 F.
    I've only done that a few times.
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
    Everyone should do it before their car is pulled apart for a four year restoration. And never after. (#304065 was painted 6609 when I got her)
    Dec 2004
    SE Michigan
    Yep, we are of the same mindset, John. When the opportunity presents, you got to take it.
    I haven't done -10F starts, but I've done plenty of 0F starts. You get the hang of it after a while.
    Bill G.
  1. Got my Dad's 1968 911, need info & ID help
    By Andy68911 in forum General Info
    Last Post: 05-13-2013, 11:36 AM
  2. info on 1968 911 SWT owners manuals
    By mpotvin in forum General Info
    Last Post: 10-04-2011, 08:27 AM
  3. SWB ARB Options
    By Schläfer in forum Technical Info
    Last Post: 02-23-2009, 05:47 PM
  4. Can anyone provide info on this car? VIN inside
    By rockafella in forum General Info
    Last Post: 07-25-2005, 07:37 PM
