Results 1 to 8 of 8
Thread: State a price : thermostat 2.2S
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    hello
    I have found these parts to buy but I have a problem to state an honest price for the seller and me.
    So could you help me to define it or a range?
    These parts must be disassembled and cleaned before being reused.
    Thanks all for your help
    Manu
    PS : if this thread is not regular delete it
    Condition of the threads are key for these. I have seen them on eBay a couple of times, but I can not help with what pricing they are. As a comparison, the 72 housings go for around $250 without hoses.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    I would pay 300$ at least for part #1 if it is not corroded on the right part that goes through the wall and on to the tank. The lip around the large o-ring is usally badly corroded.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Hi Manu,
    last complete unit i saw on German Ebay was approx 750€
    Last i bought was 80€ (lucky),came with the Behr fender oil cooler
    Manu,
    Prices are all over the range somewhat regardless of condition! There were two versions of the oil filter console (part#1). One in Aluminum and one in Magnesium. The mag versions bring a little higher money. A mag version of the entire set sold recently on eBay for $1400! Even this seems a little high for the condition it was in. But, when you need the part...
    http://cgi.ebay.com/ebaymotors/ws/eB...AVRI&viewitem=
    Typically, the aluminum set-up should be in the $500-$800 range.
    Peter
    Nov 2004
    Thanks to all
    I will verify what type it is (mag. alu.)
    I'll talk with the seler with your range value.
    Manu
    I sold an entire set last year including the tank and front cooler, with all associated parts for about $1,500.
    Oct 2008
    Burford, ON, Canada
    I saw a poorly advertised oil tank, with all the plumbing barely visible in the poorly lighted picture, go on eBay last year for about $50.
  1. State debt
    By dmundy in forum Off Topic
    Last Post: 08-14-2010, 11:35 AM
  2. tri-state (NY/NJ/PA) tour Aug 7 or 8
    By blucille in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 07-18-2010, 04:55 AM
  3. PPI in NW Washington State
    By edwardnichols in forum Technical Info
    Last Post: 05-23-2010, 09:06 PM
  4. State of the Club...
    By Chuck Miller in forum Membership Questions
    Last Post: 01-19-2010, 06:59 PM
