Results 1 to 10 of 10
Thread: Its done....
    Its done....
    Finally got my R clone on the road yesterday...the new 2.7 RS spec engine fired right up. Here's where I started
    http://forums.pelicanparts.com/uploa...1178500893.jpg
    http://forums.pelicanparts.com/uploa...1178500907.jpg
    And here he is completed....breaking in the engine
    http://forums.pelicanparts.com/uploa...1243742042.jpg
    Took a year longer than it was supposed to, but it was rough and to quote Tom Petty, "I won't back down"
    http://forums.pelicanparts.com/showthread.php?t=345183
    Cleaned up and cobalt blue...
    http://forums.pelicanparts.com/uploa...1243742827.jpg
    http://forums.pelicanparts.com/uploa...1243742870.jpg
    http://forums.pelicanparts.com/uploa...1243742945.jpg
    http://forums.pelicanparts.com/uploa...1243743002.jpg
    http://forums.pelicanparts.com/uploa...1243743044.jpg
    He's not an S but he now has a pedigree....09 Keystone parade...here we come!
    Cheers
    Speedo
    __________________
    1976 911s 3.0 "Esco"
    Apr 2004
    That was a great thread to follow.
    Nicely done.
    As we say here in Maine - Ain't you clevah.
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    You must be happy with all the work that you have put in, outstanding
    Tony
    Its done....
    Speedo, I'll look for you and the car at Keystone, shouldn't be too hard to spot your car
    Looks great!!!!
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    fabulous! great job! the poster child for low profile .... on some of the shots it looks like its lower than a GT3RS !!
    '72T Coupe - Sepia Brown
    Hats off!
    Well done and welcome.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Squat...and reflectors
    Thanks for the pics Raj...
    The Scarab Blue car was an influence in my decision to do the car and color choice.
    Squat...I think I have 3-4 degrees negative camber in the rear, which may or may not change when it gets corner balanced. It does look good, and fortunately I can stuff 15x7s in the rear without having to flare the rear quarters. I went back and forth on the "flaring"....and ultimately decided not to, as a result of the vast amout of other repair work that was necessary to fix the chassis. I did however roll the fender lips.
    The reflectors are a good accessory idea...I hadn't thought about. I'll need to source a pair of those.
    I fabricated a period correct roll bar that mounts to the longitudinal vs the floor, and welded in the feet to bolt it to, but for the time being will not install it.
    I built up a 7R 2.7 RS spec (mahle 8.5:1) carbed engine with E cams. The oil system uses a 72 console and the oil tank is in the correct place (behind the passenger lockpost) with lines feeding a big setrab cooler in the right front fender. As this is a driver vs a racecar, I did not see the need for the pair of coolers. As the car stands, the oil system is already quite complicated. I might add that to get the line from the bottom of the oil tank to the feed (the line that goes through the engine mounted oil cooler) past the rear wheel, I had to filet open the right rear longitudinal and lay the oil line inside and weld it shut. It exits the longitudinal behind the wheel and then connects with the feed line. The PP thread shows this in detail.
    The engine has about 30 minutes run time...I have been seating the rings by driving from where I live at 8100 ft up and down my road to get even top and back pressure. With the E cam, the engine is pretty responsive low and pulls strongly to the current 4500 rpm limit. I'm happy with the 2.7 choice and the 2-in 2-out exhaust is just raspy enough. I still need to do a final adjustment of the carbs for my altitude.
    Corner Balanced and Aligned...
    I got the car sorted this week...little change on the ride height. Now I have a positive rake.
    http://www.early911sregistry.org/for...1&d=1244936337
    http://www.early911sregistry.org/for...1&d=1244936404
    http://www.early911sregistry.org/for...1&d=1244936472
    I need to get a set of repro seats...some ST and /or R seats. These nice comfortable stock seats will be for sale shortly...maybe with headrests.
    Lars,
    Great to see the finished car! I really enjoy see these "alternative" cars being built and even more so seeing them built by the owner. I wish I had a fraction of your skill set. Great job and thanks for documenting the entire process!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
