Hi all,
I have been lurking around for some time now and I have done some posts, but I thought it would appropriate to do a little introduction.
Let me start by saying how much I appreciate the forum and the wealth of information that is available on-line and of course through the participating members. It is helping me a lot with my little project and the reason for my lurking
I am in the process of building a 911R replica. "Another one", I hear some of you say, but believe me, on this side of the pond (Europa that is) it is a pretty unique project. More specifically, in The Netherlands where I live, I have not heard of such project. Allthough the cars originally come from this continent, I guess you guys have simply taken the lead in building hot rods!
The basis is a 1967 911T (originally a sportomatic, I bought the car with a 901 gearbox), delivered in Germany but after having spent a big part of its life in the USA, corrosion is not a big issue. The underbody has been ice-blasted and is now clean. I have replaced the entire roof to get rid of the sunroof and to get some more rigidity in the chassis. In order to achieve even more rigidity, additional welding is done to the chassis and a roll cage is installed. A 85 liter tank will be adjusted for centerfilling and installed. Two front oil coolers with a sidefiller will also be part of the work. Front fenders, doors and hoods will all be fiberglass, Lexan window where appropriate. I have sourced original 7J Fuch wheels, they will be teamed up with monoballs and Billstein suspension/dampers. The interior will remain pretty empty, with RS lightweight floormats and likely Cobra FIA seats (safety comes first...).
Engine wise, I am trying to stay close to the carrera 6 engine. We use a 901/6 aluminium crankcase that will need to get worked for a bigger oilpump etc. I am proud to have secured things like original Mahle 906 cylinders and piston, 906 camshafts, 1964 original 906 camshafthousings, NOS heads to be adjusted for larger valves, 906 race rockers, chainhouse with centerlub, most of the NOS exterior lights, etc. One of the last things on my list are titanium rods, if I can find them at a "reasonable price". I have chosen to use a rebuild 911SC NOS electronic distibutor with original NOS Bosch cap and rotor for the twin spark - working these 4 points is too much trouble. Not sure about the fanhouse size yet. The transmission with be the standard 901 'dogleg' transmission, standard ratio's for now, with a Wevo box to get more secure shifting. I am still debating to edge and lighten the crankshaft.
Overall, I am trying to keep the weight to around 800kg and have the engine produce 200/210 + hp in a not to narrow powerband.
Anyway - these are just some details of a project that I hope to finish in the beginning of next year. I drive some more Porsches, but they are not 'early' enough for this forum. That does not make them less pleasant to drive
Thanks for listening and I hope I can provide a positive contribution to this wonderful forum going forward. Best from The Netherlands - Dick
