Thread: Heat...
    Heat...
    When my daughter is travelling with me, on the back seat of my 911, she sometimes complaints about the hot metal hinges (dunno if this is the proper word) of the rear seats. She got one soft burn on one arm once...
    Any thoughts on this subject? Anyone had the same problem?
    Vasco Ricardo
    "I spent a lot of money on birds, booze and fast cars. The rest I squandered." - George Best
    Early 911S Registry member #1067
    RGruppe member #609
    Vasco,
    Although I haven't traveled in the back of a 911 in some time let me take a guess...
    I would think that if your girl's arms are coming close to the rear seat back hinge bolts; the outside ones are close to upper end of the heat exchangers/ heater vents, and the inside ones are close to the differential - the consistently hottest part of the driveline.
    ...... again, just a guess
    Cheers
    Aug 2006
    Chicago area
    Vasco, maybe try having your daughter ride up front with you...
    I am with Chuck on this one. I do believe that he has found the culprit.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Cool ...but how do I solve it?
    Thanks Chuck!
    Hi Scott!
    YES, that's should be the problem Chuck, but how do I solve it?
    I guess I could get a sort of an "extra-cushion" over the rear seats...
    But I'd like to know if other members of the forum had this same problem with they sons, daughters or rear passengers in general, and how did they solve it.
    Or am I the only guy driving with kids in the back of my 911?!
    Vasco Ricardo
    RGruppe member #609
    ...weekend bump...
    Vasco Ricardo
    RGruppe member #609
    Sep 2006
    Maryland
    First, get it on a lift and inspect underneath the area, make sure everything is as it should be.
    You may try some heat reflective insulated padding, the kind that is used to protect from hot exhaust. Some types have a adhesive backing that you can stick up underneath the bottom of the car. Clean the area very well prior to application. Where to get it? I Googled "Adhesive exhaust heat shield" found this
    http://www.heatshieldproducts.com/heat_shield_mat.php
    Rob Abbott
  1. Heat exchanger 101
    By beaker in forum Technical Info
    Last Post: 10-29-2009, 06:27 AM
  2. WTB - set of heat exchangers for 69T 911
    By beaker in forum For Sale: 911 Parts
    Last Post: 08-22-2009, 07:48 AM
  3. In defiance of the heat....
    By berettafan in forum Off Topic
    Last Post: 08-18-2009, 09:37 AM
  4. Too much heat!
    By PNW 73S in forum Technical Info
    Last Post: 08-07-2002, 06:30 PM
