Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: carrera rs v 70 911 s
    Am I crazy or not. I have the rs for a month now and I like the useable power of my S better. That sweet 2.2 motor. The S seems to be more interactive and involving to the driver. Am I making sense?
    The S motor can be winded out more and because the geering seems shorter, there is more shifting and higher revs. The S feels a bit heavier, but in a good sense. Where am I going with this......
    RGruppe member 445
    I would be happy to volunteer a test drive on both cars to confirm your findings
    I have a website now:
    www.markmorrissey.org
    Instagram: @Mark0Morrissey
    Maybe you should drive a 912 or a 2.0T for a few weeks and then get back in the RS. All symptoms would surely be cured.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Nov 2003
    Santa Monica CA
    RS vs. 911S
    Like the saying--Its more fun to drive a slower car fast than to try to keep a faster car under control. Chris 70S , S Reg.#205
    I would say your RS is not performing as it should as there would definately be no comparasin if it was....
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Sorry - I'm with Boyer on this - your RS should feel completely different and it does sound as if it's not set up right.
    The RS really changes character at 5k and from that point should be a banshee!
    1973 911 Carrera RS #496
    Early 911S Registry #1808
    Nov 2003
    Sydney
    John,
    You have to remember that both models are pivot points in early 911 history despite both being grouped together as 'small bumper' 911s.
    The 2.2 S was the last of the high compression / revvy motor / 911-901 trans series and the RS was the first of the low compression / higher mid range torque / 915 trans models.
    They both respond to slightly different techniques in driving to deliver optimum driving pleasure.
    You will find that the RS will ultimately be the faster 911 due to its increased mid range torque and the ablility of the 915 to translate this torque into road speed.
    On paper there is only 30 bhp difference in the two so you would think there shouldnt be that much difference in the end performance feel.
    Due to the first gear on the 2.2 S having to be treated more respectfullly and the torque curve not being as good as the RS,the 2.2 S doesnt feel as fast as the RS.
    The RS's 915 on the other hand is a much stronger trans that can take all the torque / power the RS has to give.
    My experience in this area is 13 years with a '75 Carrera 2.7 (RS running gear) and 5 years with my current '71 2.2 S.
    My preference,despite the Carrera 2.7's overall performance advantage,is for the 2.2 S as it is a more involving drive.
    It takes me back to the times when driving was a skill/technique to be rewarded.
    Mind you I would still like to have both in the garage...
    (...gets back down from the hobby horse...)
    Cheers,
    Dennis.
    S Registry member 536
    Your RS needs a tune up.
    I see everyone's point and do not disagree on some level. The car runs fabulously and just went through a full tune up with valves and MFI. It runs very strong. It is more about my finding that the 2.2 s motor can be fully used around town, requires more shifting and is, perhaps a more intimate experience for the driver.
    Third gear on the rs pulls at 2500 rpm up to 7000. That rpm range means one can be in third gear for very long periods of time, hence no shifting and less driver involvement. The 2.2 s motor and transmission gearing are much different, hence more driver involvement.
    The thinner tires on the s, also seem to make the driver more involved. For some reason the rs feels like a departure from some of the earlier values. Knowing the motor is a step up from the 2.4 cars, I have heard many people state that with the reduced compression ratios of the 2.4 and 2.7 cars, that the 2.2 motor seems special and more fun to drive.
    Perhaps, it is just an opinion issue and not something everyone would agree upon.
    RGruppe member 445
    I agree my 2.2. s was a very engaging car one had to use the gears all the time, nothing happens under 4500 and I was always winding it out to 7000 for the fun and to hear that whine! BUT The 2.7 has so much torque in comparison the character of the car changes completely you can achieve better performance with less effort and if you are really working it the 2.7 is very satisfying. When I had my 2.4 converted to 2.7 the car came alive. If you are in the wrong gear in a 2.2 your going nowhere, in a 2.7 it pulls in any gear. Torque, not horsepower is what gets the job done.
    I had an 1100cc Simca when I lived in France and I had so much fun with that car, going to work was like driving in a GP car except you were only going 50 miles an hour.
  1. Carrera 3.0 and Turbo 3.0 (turbo carrera) register
    By Bertroex in forum Other Porsche Passions
    Last Post: 07-16-2023, 08:37 PM
  2. FS: 4 original riveted alloy rims wheels for Porsche 904 Gts Carrera , 356 Carrera 2
    By 911 SWTARGA in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-21-2020, 05:05 PM
  3. WTB: 911 Carrera Cup
    By 67er911S in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 12-08-2013, 11:04 AM
  4. 1986 911 Carrera/Euro 74 Porsche Carrera RS (clone) on the Bird
    By byron in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-15-2009, 10:25 AM
  5. '75 US Carrera
    By RTincher in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-12-2008, 05:06 PM
