Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Suppose we build....
    I think the factory doors (sans window mechanisms) are around 37-38 lb. You can cut much weight out of the complete assembly by going with Lexan windows with a pull strap. FG doors are also availalbe, and can be fit pretty well if you really want to cut weight. It is possible to get a 1750 911 if you really want to go the FG/Lexan and stripped route...it was done in '67....I think.
    Every feature on these long hood cars can be lightened, but some of these techniques will be more modern than in the day...so like everything else in life, it ends up being a compromise. Throw safety out the window (along with heavy windows and doors) and you can have a sub 1800 lb 911. Then stick a 200-250 hp engine in it, and it goes like a scalded dog. Many have BTDT before.
    Gib
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Foam = Sponge = . . . .
    Quote Originally Posted by Jens View Post
    . . . I've used 2-part high density polyurethane foam to reinforce body panels to pretty good effect.
    Attached are some photos of what happened when 'foam' was sprayed into a Porsche --- specifically my Porsche. Basically, the 'foam' turned into a 'sponge,' that over time caught and held moisture, which then rotted-out the panel.
    From my experience, introducing foam into an ungalvanized metal structure . . . is a really, terribley, hugely BAD idea.
    Rick Kreiskott
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Exclamation
    ... introducing foam into an ungalvanized metal structure . . . is a really, terribley, hugely BAD idea. Rick Kreiskott
    Closed cell ballistic foam wouldn't oxidize quite so readily (terribly or hugely) in a composite or aluminum bumper. Nightmare avoided!
    And Rick, what I did to that hapless WV bus was effective in a way, but irresponsible. I was just a kid living in the now, but I knew it would rot out... sometime after I was long done with it. So it went.
    RGruppe #183
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    I've seen the same issues with 914's around the upper corner of the rear fenders by the taillight and at the base of the sail panel. The factory sprayed foam in there and it did/does exactly as described above.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    We'll Make Your Calipers New Again
    Love Us On Facebook
    I would think that is water was getting into that rocker it was probably going to rust out anyway. I've seen plenty of rusted rockers, none with foam inside. he question is: which way will it rust faster?
    Aug 2003
    vahmont
    Right Jim, I was thinking the same think. In some locales they rust just sitting all by themselves doing nothing but passing the time, without our help.
    RGruppe #183
    So? . . .
    . . . where did we leave all this?
    Olde Threade Alerte!
    Any genuine 'light-weight' parts being offered? . . .
    . . . anywhere?
    Senior Member uptheorg's Avatar
    Apr 2012
    Scarsdale, New York
    Rick,
    I've heard that you can cut a lot of weight by losing that gut and driving in the nude.
    (Just a couple of cheap suggestions)
    __________________________________________________ ___________
    Early S Registry #2359
    1970 Porsche 911 Rally 2.4
    2018 Porsche Macan GTS
    Atlanta, GA
    Someone needs to make quality Carbon Fiber parts. Besides Singer.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  1. Another 72 ST build
    By BOYER73S in forum General Info
    Last Post: 05-20-2023, 07:39 AM
  2. Build # vs VIN # 70S
    By TPC in forum General Info
    Last Post: 06-08-2014, 09:08 PM
  3. 2 be or not 2 be. Build as a 2.0 or 2.2
    By beetle08 in forum General Info
    Last Post: 12-12-2012, 12:41 PM
  4. how does the rear fog light suppose to work?
    By lemonlib in forum General Info
    Last Post: 10-05-2012, 06:59 AM
  5. Hot Rod Build
    By Max (SD) in forum General Info
    Last Post: 02-08-2007, 08:43 PM
