Results 1 to 7 of 7
Thread: engine case type
    engine case type
    Hi,
    My father is on the way to re built an engine "told" from 906.
    Ok, some parts have good references but the engine case is not the original at all.
    Ref are:
    901.101.101 7R on the left
    901.101.102 7R on the right
    Does anybody can tell me from which model it is coming from?
    Rgds
    Freddy
    Oct 2008
    Burford, ON, Canada
    Nope, those are case half casting numbers for the "7R" late magnesium case from about 1974 2.7 engine.
    If it does not have proper serial # or type # stamped into it, then it is a replacement case.
    Aug 2007
    Phila Pa. area
    906
    The 906 case was a 2liter sand cast Mag case,Regular street Mag cases are smooth and used an injection moulding process.
    Mike
    If he wants to build a 2.0L out of a 2.7 case than he has to issues:
    the distributor is smaller than what the case takes
    the cylinders are of course a lot smaller
    Does your father have a true 906? There are at least 2 cases out there.
    Richard
    Thanks for iformation.
    Only the motor has to be remounted.
    I need only the real references of engine case, i'm quit sure that the one used are adaptations.
    Rgds.
    Freddy
    Aug 2007
    Phila Pa. area
    case
    [QUOTE=ydderf911;220217]Thanks for iformation.
    Rgds.
    Freddy[/QUOT
    what are you talking about?
    Mike
  1. Type 901/xx Engine Build #'s
    By davep in forum Technical Info
    Last Post: 03-22-2024, 07:26 AM
  2. FS: Aluminum Engine Case - Type 901/01, Engine 902409
  3. What type of early 911 engine is this?
    Last Post: 05-01-2006, 08:10 AM
  4. What type of 911 engine is this?
    By 72targa in forum Technical Info
    Last Post: 03-23-2006, 03:33 PM
