Results 1 to 2 of 2
Thread: 3.2 in 73T correct sensors for oil temp and pressure
    I have a 73 with a 3.2 conversion. I believe the oil status monitoring gauge is correct for the 73 and I think the sensors are still 87 carrera bits. So unless I'm idling in crazy hot weather the temp gauge never lifts off it's bottom rest and the oil pressure is 60 when idling and pegged at max when driving. My question is how to correct this so I can guess what my engine is doing instead of just hoping everything is fine?
    I've been told that the sensors are different for the models and that I can just change the snesor to one that has the correct output range, I've also heard just to send it to Hollywood Speedo and let them fix it. Which is more cost effective? If I change the sensors what part numbers do I need?
    Thanks Mark
    Mark
    1973 911T Targa 3.2 hot rod - Sold
    1992 964 C2 - Sold
    1988 VW Single Cab Truck - For Sale
    1985 VW Double Cab Truck
    May 2006
    CT
    Mark
    It will be easier to install the correct sensors.
    I've got them if you need them.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  1. FS NOS 70-73 E-S combination oil temp/oil pressure gauge
    By Oceanshore-ms in forum For Sale: 911 Parts
    Last Post: 11-11-2012, 05:21 PM
  2. Oil Temp and Pressure Sender Compatibilty
    By 50/50 in forum Technical Info
    Last Post: 07-08-2012, 02:18 PM
  3. Oil Temp/Pressure/Warning Switches
    By Fishcop in forum Technical Info
    Last Post: 02-09-2012, 06:59 PM
  4. Whice temp/pressure sensors to use??
    By desertpagoda in forum Other Porsche Passions
    Last Post: 02-26-2011, 11:21 AM
  5. 68- Sporto Oil Temp/Pressure Gauge NOS
    By jbell959 in forum For Sale: 911 Parts
    Last Post: 12-05-2007, 08:34 PM
