Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Short or Long stroke
  1. #31
    Long Stroke case and broken crankshaft
    This is a longstroke 2.5 case (911/70) and a crankshaft that I broke a few years back. The engine still ran well enough to get around the track and then shut it down. I found that I could wobble the pully by hand without much effort. Fortunately the case was not destroyed as this is the original case to the car. This case is now a shelf decoration and the crank will make a nice lamp someday.
    Matt
  2. #32
    911/70
    Matt:
    Please tell us:
    Was the 70.4 crank cross drilled?
    Was the original 911/70 case shuffle pinned?
    What flywheel was on the engine when the crank broke?
    Are you building a the replacement engine to shortstroke of longstroke specs?
    Thanks, Tom
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
  3. #33
    Hi Tom,
    The crank was not cross drilled.
    The original case is a 3R/3R and was not pinned.
    The flywheel was stock (nothing lightened).
    The next engine is a long stroke built on a 7R and shuffle pinned with crossdrilled crank and standard flywheel.
    Matt
  4. #34
    Sounds good. Make sure your chain covers are shuffle pinned and you have a big oil pump.
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
  5. #35
    '72 911T 3,0 liter MFI Albert Blue street/DE toy Jeff Higgins's Avatar
    Jul 2006
    Lynnwood, WA
    Randy - I've never heard of shuffle pinning chain covers until you it mentioned earlier on this thread. What does that do for the motor? Did you do that on your 2.8/2.7, and is it something I should consider on my 3.0?
    "God invented whisky so the Irish wouldn't rule the world."
  6. #36
    me too? Gordon
  7. #37
    Mike Reischel recommended it with early aluminum cases used in high horsepower application, since they do not have as many locating pins in this area as later cases/chain cover housings. Apparently there have been some leaks in this area in some of the vintage race 911s using early aluminum cases, and the additional locating pins prevent this from occurring. I did not add more pins in this area on the first build of my motor (and did not experience any leaks), but we did add them during the second build since we had the time. A later aluminum case has these extra pins already, Jeff.
    Randy Wells
    www.hotrodfilms.com
  8. #38
    Jul 2006
    Lynnwood, WA
    Thanks for the explanation, Randy. So, essentially, it's just a matter of applying a later improvement that Porsche had come up with to their first effort at 911 cases. There are a couple of dowel pins at the chain box to case seam on my motor, so I guess I assumed they all had that. I could see where they would be needed as power and rpm's increase.
  9. #39
    Me too, OK. The update is a good thing. The two per side solid dowels are removed and in there place goes studs and hollow dowel. Gordon
  1. 2.2E Mild Upgrade. Short stroke or long? Opinions Please!
    By wagonboy in forum Technical Info
    Last Post: 01-13-2018, 09:24 PM
  2. Short stroke options
    By saintdave in forum Technical Info
    Last Post: 11-15-2009, 05:28 AM
  3. S/T 2.5 short stroke twin plugg
    Last Post: 06-16-2009, 09:32 AM
  4. Short Stroke Rods and Correct Air Compressor for 73RS
    By byron in forum For Sale: 911 Parts
    Last Post: 04-21-2008, 09:52 AM
  5. Specs of 1971/72 2.4L short stroke MFI racing motor?
    By kenikh in forum Technical Info
    Last Post: 09-08-2005, 04:26 PM
