hey you original paint guys.
is this paint scheme correct for a 72?
or should the hinge plate and latch mechanism be unpainted?
and is the black background correct?
(this is from darryls 912)
a picture from an original 72 would be great!
thanks
bob
thanks
bob
bob moglia
'72 E sunroof coupe
Bob,
I have never seen the inside painted black before.
1965 911 #301111, Red Book Vol 1 "Cover Car," owned 53 years.
1967 911 #307347, bare-bones, some road wear, a little surface rust, and a few dents..., owned 13 years.
Registry #983
R Gruppe #741
thanks john,
do you recall if the hardware is painted or not?
bob moglia
'72 E sunroof coupe
Rob, everything was painted assembled, the filler neck wasn't installed nor was the rubber cuff. The gas door was installed, so the exposed ends of the bolts were painted. The latch mechanism spring and cotter key was installed and painted. You want to put the rubber buffer in, and adjust the height of the latch arm for gas door fit, before the fender is installed. Getting access to the adjustment bolt after the fender is on will make you not want to do that again. Remove the rubber buffer before painting. The fender was installed before painting which is why you'll see paint on the fender attachment bolt heads except the ones retaining the trunk carpet snaps. The bolts at the cowl were left loose so the beading could be installed after painting.
thank you ed
BTW what happened to your front pan replacement site?
its gone and missed!
i tried sharing it with others but no go.
it was my main reference for my repair.
bob moglia
'72 E sunroof coupe
Here is the fuel fill in my 73, which has original paint.
Tom F.
Long Beach, CA
It went away when we changed servers, PM me your e-mail and I can do a link.
