The original engine number in my 68 was 3380028 and it was a 901/17 but I'm not sure if it was aluminum or mag.
I have a spare engine 3380373 901/17. It is a mag case.
Approximately how much time passed between those two numbers?
Thanks!
Thanks!
Hi Mike,
Porsche made about 7,000 911s in 1968, first order ~20/day. Roughly estimating for the difference of ~350 engines, I'd say a couple weeks plus or minus. Of course there are all kinds of other factors, S versus normal, possibe holidays, etc. but this should get you pretty close. Your original engine was Alu and the later one is Magnesium; the numbers in the chart below show the last alu. engine numbers. Probably when your car was converted from a Sporto, they took out the engine/tranny and put in the manual tranny with its attached engine. Do you know if the engine/tranny numbers in your car now, more or less, match by date code?
-Allen-
Mike, Allen:
Here is an L case:
68L coupe
Engine type: 901/14
Engine number: 328055O
Case material: Aluminum (as predicted by Allen's data)
Early 911S Registry
Looking for engine 960 168
Looking for gear box 103 165
Tom,
Please post some pics of your date stamps on each side of the case. Thanks.
-Allen-
Hello Allen:
There are 10 dots around 67.
Does this indicate a foundry date of October 1967?
Sequence number is 11773.
Tom
Early 911S Registry
based on the build #'s 3380028 would be after 10500 and 3380373 would be before 16000, so possibly 4000 to 5000 engines built between them so I'd estimate 30 weeks between them.
I looked at sporto data only and I think Dave is right. The last /17 engine in the series was 3380463, so there were only 463 U.S. spec. sporto engines made in '68. 30 weeks is a good estimate. But Mike, you can help with your question, what is the date stamp on your spare engine? Thanks.
-Allen-
