12 days into it since delivering the SC to Franz Blam Racing. A lot of progress so far. The entire front suspension from the SC including steering and brakes has been fitted and mounted in the 67. A mock up of the 3.6 block and 915 were fitted in the 67 to check for clearances and fit. Oil lines to the right front fender have been installed along with the SC oil tank. Electrical work has begun including installation of the 12 mini-coils or whatever they are called for the crank fired twin plug set-up. All of the instruments from the SC will be moved to the 67N. Currently waiting on Pelican for beefed up rear suspension parts. Received adjustable spring plates and new wheel bearings today, waiting on 26mm rear torsion bars, 19mm sway bar, Wevo mounts, rear Koni's and a couple of seals before mounting the 3.6 and 915. The trailing arms from the 67 have been bead blasted, reinforced and powder coated. The half shaft lengths will need to be measured once the suspension and engine are in and then fabricated. Another completed item is the 915 shifter,tube and coupler. Had some problems with the wheels. Had them blasted with walnut shells to knock the paint off but could not polish them because they were anodized but then a friend, John Holt, knew a guy who has some magic elixir that removed the anodizing and a little elbow grease later with Mother's aluminum polish and a power ball brought out a decent shine. Had new Goodyear Eagle GT 195/65/VR15's mounted Saturday. Sorry for the sh***y pics, been using my Iphone but it's coming along and I'm getting really excited. Note Thomas Blam in one of the pics. Same Thomas from Flying Lizard as in the new Panorama. Check the “For Sale” listings in the next few days, will be selling a lot of unneeded parts to make garage space and help fund my insanity. Future plans include Dynamat's covered with a RS Carpet set and Monte Carlo Sport Seats on order from Pelican, a tall OE type Roll Bar from TRE and then corner balanced, lowered and a little dyno tune.
prior thread here:
http://www.early911sregistry.org/for...ad.php?t=27281
