This is an extensive list. I have tried to organize it by category. If you have questions or desire pictures, full size pics and more details can best be done via email. Also, I am motivated, seriously, really. So, if you have some interest in something, I want to make it happen. Not happy with your purchase - let me know - I will make sure you are
BRAKES/SUSPENSION/MISC:
911S Alloy Brakes, need rebuild, $300 for the pair
1972+ 911S Koni Front Struts, need inserts, $500 for the pair
Brass Euro 28-Row Oil Cooler, good, not bent, just dirty, $300 ($400 with 3.2 Carrera thermostat)
Interior:
RS door panels - "Bamboo" top-grade perforated vinyl (1970s Mercedes material) - done by TRE, only one hole for door pull, ready to go any direction you want. $190, material for the rest of your interior IS available (See sample photo below)
Jackie Ickx MOMO (350mm I think), nice leather, some scratches on the face, $165
Old school (1979?) MOMO Prototipo (350mm), patina/wear on the leather, still a good wheel, $165 (no horn button)
Tan S/T Seat $650
EARLY ENGINE:
2.4/2.7 Crankshaft - good- standard/standard, ready, $375
Connecting Rods - 2.0,2.2,2.4,2.7,3.0,3.2/3.3, lots of weight groups, good condition, matched sets available, - $7 each
3-Bearing Early Cam Towers, 1965-1977, Completely gone through and cleaned by Ollie's, for RS engine, did not use, ready to install 100%, concours perfect, $150
RSR cut/lightened 1970-1977 Flywheel, fresh, ready, done by Ollie's, pending
MFI - MECHANICAL FUEL INJECTION:
Random velocity stacks, lines, hardware, filter consoles, belts, pulleys, air cleaner boxes, linkages, you name it, anything MFI, I pretty much have. $TBD
Plated Engine Hardware -- have virtually everything -- ask
3.0, 3.2 ENGINE:
3.0 SC Engine Case, Euro, 930/10, 1981, Very Good, no stories, $650
3.2 Carrera Engine Case, 930/21, 1987, Very Good, no stories, $850
3.2 Carrera P/C Set, Good, Nikasil, or possibly just use the cylinders for your JE pistons - $500
4-Bearing Cam Towers, $175 / pair
3.0 Flywheel, core, has enough material to resurface $80
Valve Covers, Aluminum, Upper, $100 /pair
TRANSMISSION: (pending?)
Complete 5-Speed 911/01 1970-1971, removed from 911T, good working
1967, '69, '72 Trans. Cases, 902/1, 901/01, 915/02, VG
915 Gears-all stock gears avail., '72-89, VG
901 Gears-Sliders, A, GA, N, O, S, U, V, X, Z, ZA
901 7/31 R/P - Perfect
Also have bearings, forks, detentes, springs, sliders, whatever you might need to service your transmission.
Send inquiries to Kindersport@gmail.com, or call , 818-406-6053
Thank you
Scott
