I have a fan housing strap I would like to have cleaned up and re anodized. Can anyone refer me to a vendor that does this at a high level?
RGruppe member 445
John-
The fan strap is steel, so it is either painted or cad/yellow zinc plated, depending on the vintage. What year is this for?
Early S Registry 1047
’15 VW GTI
'70 911E, Sold
'56 Cliff May Prefab
That strap is made of steel, and is plated, not anodized.
JZG
Plating tends to have large minimum orders, so I would send to Eric at PMB Performance (Neunelfer, our resident caliper restorer) and have him do it with one of his other orders. I've found the work to be high quality. USPS flat rate boxes are cheap shipping.
I thought is was anodized. So plating it is. Any names or companies I can call. It is for my 1970 S.
RGruppe member 445
John,
Is this for the RS or the S? If it is for the RS and the strap has 1 bolt (a later third series will probably have one bolt) have it plated, but if it is for the S or your RS has 2 bolts then it should be painted black.
Brian
'71T
R Gruppe #299
If it's for your '70S, then it should be painted black.
’15 VW GTI
'70 911E, Sold
John, I agree that it should be painted black but if you decide you want to have it plated PM me. Im having a group of stuff done (either yellow chromate or clear zinc) and Ill get it done for you no charge as long as you pay for shipping.
1997 993 C4S, Not totally stock
2015 GTI
1991 E30 M3
1970 911T, Lilly. Slate Gray 3.2ss PMO etc Sold!
http://forums.pelicanparts.com/porsc...ect-lilly.html
Early S Register Member #1386
