Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Two different length ARB drop links!
    Well it seems that the more time I spend with the parts for the restoration of my 1966 911, the more I realize that the Factory made a lot of changes on the run. . . I have to check the parts book, but it looks like there was a change in the length of the ARB drop link along the way! Check these out!
    Both are 901 343 076 03. . . I think. Have to check the old book for a different number.
    I sourced some LWB hardware for the ARB, presuming it was "identical." Does anyone know which is SWB and which is LWB? I suppose I could figure it out from the amount of "droop."
    It DOES provide a measure of adjustability, though! One long link and one short to dial out the preload. . .
    John, I'll try to remember to measure the ones on my 67 since they're off and handy, tomorrow when I go to the shop. (this something I certainly wasn't aware of )
    May 2005
    Oroville, CA
    My SWB parts book shows a 901 343 076 01. LWB book shows a 901 343 076 03.
    H
    Ed, that would be excellent, thanks. I'll post the center-to-center length on Sunday.
    Harvey, thank you very much for looking it up, that is a big help. Now I just need to figure out which is which. I have new bushings and steel inserts ready to go.
    Thanks gents! Stay tuned for more mysteries as I turn a big pile of parts into a running car!
    May 2005
    Oroville, CA
    Next problem, my 66 and my 70 measure about the same (Approx 8 3/4 C to C). (Upside down with a yardstick in the dark) Hope you have better luck. My 66 had sways added later so they may have used the late ones?
    H
    Dec 2006
    Las Cruces, New Mexico
    My 67, 9 3/8" c to c.
    Early 911S member #166
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    The ones that came off my '66 are 24mm C to C. I have another set, of unknown origin, that measure 23mm C to C. I never noticed they were different.
    Rich
    1966 911 #303872
    ES#1197
    RG#478
    Dec 2006
    Quote Originally Posted by Rich Lambert View Post
    Rich, those are sure short.
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    914 arms are the same but shorter.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Short / Long
    I just measured a set from a 67 S = 24cm Also I have a new set bought on eBay and they are 23cm ,mabe 914 & later 911?
  1. Are All Drop Links for Front Stabilizers the Same?
    By mshaver51 in forum Technical Info
    Last Post: 08-02-2013, 04:21 PM
  2. FS: 15mm Sway Bar w/Drop Links
    By Gray in forum For Sale: 911 Parts
    Last Post: 03-29-2013, 09:30 PM
  3. FS: Rear sway bar drop links for an SC
    By EA911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-30-2009, 03:01 PM
  4. SWB front ARB drop links
    By tomkirkcis in forum General Info
    Last Post: 09-23-2009, 05:14 PM
  5. Drop links rear sway
    Last Post: 06-15-2008, 12:07 AM
