Two questions come to mind. . .
#1-- I managed to LOSE the little square-section o-rings that go on the stub axle after the bearing retainer cup. Part number 901 331 283 00-- NLA! Photo attached so you can see what I mean-- also shown as Nr. 17 in the diagram, or #11 in the cutaway view of the axle.
The diameter of the stub axle is 30mm. I remember what these looked and felt like, they were square section, and about four or five mm on a side.
Mcmaster has some square-section O-rings that are 1-3/16 (30.16mm) ID, 1-7/16 OD (36.5mm), I'm going to give those a shot unless anyone knows a better substitute.
Ultimately I think these are intended to keep moisture out of the gap between the hub and the stub axle. If you look VERY closely at the diagram, you can see that the hub (and its projecting "outer" part of the stub axle) makes contact with the spacer (you can even see the spacer tube, with the "recess" and "wide thrust surface" facing the roller bearing) and also with the inner race of the roller bearing. The stub axle engages inside the hub's female splines, and the gasket is used at the very end, presumably to keep water from getting in between them and rusting them together.
Now someone more experienced than I is going to say, "I never used those, have put dozens together without them!" Or is this a critical piece, such that folks have engineered a workaround?
Any assistance would be much appreciated.
Question #2. How in the world do you get the flanblocks off the end of the SWB front control arms? The factory is no help, they say that they cannot be removed without destroying the arm, and that new control arms must be purchased.
As a refresher, the rear SWB bushings consist of an inner metal race, a rubber bushing, and an outer metal race. When the suspension is installed in the car, the correct droop angle is established and then a pinch bolt is tightened around the outer race, which locks the outer race to the front crossmember. Suspension movement is then facilitated by the flexing of the rubber. As such, it's a pretty tight connection between the control arm and the inner race of the bushing.
I tried a puller, I tried my press, nada. Those suckers are ON THERE.
I haven't tried heat yet, but I am thinking of using my MAPP torch outdoors to melt the rubber to get the outer race off, then dremel the inner race to weaken it and use vice-grips and PB blaster to turn it on the control arm. Just wondering if anyone else has managed to wrangle this off without "replacement of the arm."
THANKS in advance to those who have come this way before!
JFC
