Results 1 to 7 of 7
Thread: Rear shock, lower mounting rubber?
    My 71S have correct KONI 2088 rear shocks. The rubber in the lower mounting part is no good, so I ordered some new rubber bushings from Porsche. I got part number 901.333.795.01. They seem to narrow and the hole for the metal bushings seem to small. I have attached some pics. Anyone know if I need another type and part number, or will these stretch when installed?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    John, 901 333 795 00 (or 01) is the "Boge" version, as you can see it won't work with your Koni shocks.
    You want part number 644 343 561 13. . . that is a 356 part of course.
    Check out this link to NLA. . . .http://www.nlaparts.com/store/shock-...oni-p-181.html
    JohnC, thanks! Just ordered a pair from NLA.
    Crap, NLA sent me the wrong ones.They sent me the 644 343 561 10.....they are the exact same as the incorrect Boge ones I got from porsche. I will email them. BTW I can not find the 644 343 561 13 at their site?
    Aug 2006
    Sonoma, CA
    Try these guys -
    http://performanceshock.com/shock-ab...ir-and-rebuild
    They've rebushed my Konis (1967 911s Double Adjustables) and may have your size as well. PSI is not usually in the parts business, but I could see thyem helping you out because of the distance.
    good luck
    johnt
    JohnT, thank you I will!
    I got all the help and info needed from Andrew at "performanceshock". Shipped what I needed from the US to Norway and took his time to answer all my questions, even if my purchase was very small. I must recommend them at A+.
  1. Lowering the front, remove rubber on top of the shock?
    Last Post: 09-04-2012, 03:49 PM
  2. Rear shock mounting bolt
    By spankie in forum Technical Info
    Last Post: 06-25-2012, 03:58 PM
  3. Proper mounting of swb (no rubber) front bumperettes
    By oscillon in forum Technical Info
    Last Post: 10-27-2010, 04:15 PM
  4. WTB: Rubber Grommets for MFI Fuel Filter Mounting Plate
    By RTincher in forum For Sale: 911 Parts
    Last Post: 10-01-2006, 09:03 AM
  5. Lost a lower shock absorber bolt
    By pgxif in forum Technical Info
    Last Post: 08-21-2004, 01:04 AM
