Results 1 to 9 of 9
Thread: How bad is the rust in my fuel tank??
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    Hi.
    Changed fuel lines and filter today and decided to take a look inside the tank. A bit hard to see, but there is rust at the bottom and some rusty particles. The upper part of the tank seems excellent. Surface rust in the edges on the outside.
    How bad do you think this is, and what should I do? Had hoped to avoid a full service now but think thats the only way to go.
    Thanks!
    S-Reg #1382
    67S Lavender
    Did you remove the filter sock from the outlet line, and if so was it clogged with rust particles?
    Jun 2008
    Norway
    No, not yet. Will take out the tank and inspect it carefully asap. Have only changed the fuel lines in the engine compartment, that´s the reason I have not checked it yet. Will post pictures of the filter sock when I remove it.
    S-Reg #1382
    67S Lavender
    In my experience just having some rust on the tank walls is of no consequence. But if you find many particles in the filter, remove the tank and have it cleaned and sealed. Mine filled a fuel pump necessitating replacement and doubling the cost... the price of procrastination.
    jhtaylor
    santa barbara
    Jun 2008
    Norway
    Ed/James;
    Here are some pictures. The filter sock actually looks OK. Not clogged, could blow through it. The fuel was very dirty and lots of particles. The fuel lines were totally rotten with several of the connections not even secured. The tank has some rust that has to be taken care of, but think it can be repaired. Will clean the tank now and restore it 100% next winter.
    Cheers,
    Radmund
    S-Reg #1382
    67S Lavender
    The outside of the tank looks worse than the inside! That filter sock is more clogged than you think. Use aerosol carb cleaner and keep spraying the sock and then blowing with compressed air. When totally clean you will be able to hold it up to light and be able to see through to the tube inside, all the way around the sock.
    Atlanta, GA
    This may be a dumb question, but after cleaning my filter sock I found a small hole in the screen mesh. Does that mean it should be replaced or is there a fix using new screen?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Jun 2008
    Norway
    Thanks for the advice. You are right about the outside rust. My mechanic looked at it today and advised me not to use it. He was surprised it was not leaking. The metal is very thin in some areas.
    S-Reg #1382
    67S Lavender
    merbesfield This may be a dumb question, but after cleaning my filter sock I found a small hole in the screen mesh. Does that mean it should be replaced or is there a fix using new screen?
    The filter sock should still available as a new part from Porsche. You get the whole fitting, not just the mesh.
  1. FS: SC oem fuel tank and early 65 fuel tank
    By EARLY911ZOO in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-17-2013, 05:27 AM
  2. Gas tank rust cleaning and coating?
    By Rino71 in forum Technical Info
    Last Post: 09-06-2013, 09:16 AM
  3. Replies: 1
    Last Post: 06-18-2013, 08:13 AM
  4. WTB: MFI Fuel Tank
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 02-20-2012, 06:09 PM
  5. WTB Fuel Sender for 100L fuel tank
    By jimf42 in forum For Sale: 911 Parts
    Last Post: 09-05-2010, 12:40 PM
