Results 1 to 8 of 8
Thread: Brake caliper bolts SWB
    What is the special bolt socket pattern on the early SWB front calipers? Not a Torx, I've been told. Are these even the stock ones? (The rears have allen head bolts.)
    The idiot PO left one bolt out, stripped the inside of one, and put short ones in long holes and vice versa, so I need the tool to remove these (I don't plan to separate the caliper halves). Anyone have the tool to rent? And I need two of the longer bolts. Anyone have the bolts from an old caliper?
    Thanks in advance.
    66 SWB #304307 disassembled and stripped
    Oct 2008
    Burford, ON, Canada
    Ribe, not too easy to find, but I have a supply and a supplier.
    Almost better to send that one to Eric at PMB.
    Dec 2006
    Las Cruces, New Mexico
    If you have access to a welder stick something like a allen wrench in the bad one and tack it. Put a wet rag around caliper or if you have some heat sink prior to welding. Can't help on the proper tool.
    Early 911S member #166
    Aug 2007
    Phila Pa. area
    caliper
    buy a used caliper? cannot be very expensive
    Mike
    Dave is correct - Ribe. I bought a nice set off the web for ~$60. I can get the info if needed. Several good threads on the topic of caliper restoration.
    Dave also giving good guidance on Eric - maybe send all 4 and get a first class restoration for a fair price.
    Nothing wrong splitting the calipers, but you will need new seals - still available from Porsche.
    Need to be careful in sourcing the proper new bolts as well.
    I vote for Eric x 4 calipers...
    Bill
    Bill
    1969 911T - sold
    2001 911 Turbo - sold
    1996 911 C4S - returned
    1982 911SC - gone
    1960 356 Roadster - sold
    Thanks everyone for the info and pointing me to PMB. Bill, If you have your source for the Ribe tool, I'd like that. Also, were did you source new bolts?
    Terry
    You can buy the RIBE bit from your local Wurth store.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Hi Terry.
    I got the pictured set from Tool Discounter off of the web for $47.06 plus shipping in Sept. '09. The "brand name" is SPX. It's a really nice set (and I'm a tool snob). With a quick search I couldn't find what I bought, but here are some "L" wrenches:
    http://www.tooldiscounter.com/ItemDi...lookup=OTC4609
    You will need the 8 mm.
    I reused my old bolts to retain originality - but look for an equivalent socket-head cap screws of sufficient strength. There is a good thread here somewhere.
    Tip: Use the Ribe end of the "bolt" only to keep it from turning and do the "rotating" part on the nut only.
    Good luck,
    Bill
    Bill
    1969 911T - sold
    1982 911SC - gone
  1. Brake caliper lube
    By motogman in forum Technical Info
    Last Post: 05-13-2013, 01:14 PM
  2. Brake Caliper Locked up
    By red911 in forum Technical Info
    Last Post: 09-08-2012, 06:22 AM
  3. Brake attaching bolts
    By Max (SD) in forum Technical Info
    Last Post: 01-10-2011, 06:18 AM
  4. WTB caliper bolts
    By Semjon in forum For Sale: 911 Parts
    Last Post: 10-06-2010, 08:24 AM
  5. '67 S brake caliper rebuild
    By Ed B in forum Technical Info
    Last Post: 02-24-2005, 07:38 PM
