Results 1 to 10 of 20
Thread: Will a 356 steering damper work on early 911?
    Question Will a 356 steering damper work on early 911?
    Hi,
    Anyone know if the 356 steering damper will replace the early 911 steering damper?
    My 911 is 302694 MY66 built in 65 so still pretty early. I would like to replace this as I freshen up the suspension.
    part# 695-347-501-10; Koni steering damper. Currently supplied painted black as pictured. Fits 356A, 356B, 356C.
    Joe D
    1966 911 #302694
    Mar 2006
    Louisville KY
    Stoddard Sells the correct one for your car. Or atleast they used to.
    Tony Proasi
    52 split window coupe
    Stoddard part No. 901-347-501-00 $116.00
    The part desciprtion has it as NLA? Looks like a Porsche # I will try them thanks again.
    Joe D
    1966 911 #302694
    Joe
    Write to Paul Domitrovic at Stoddard, he's a great guy and a good friend, he can tell you if its NLA or in stock
    pdomitrovic@stoddard.com
    Manuel
    They are NLA. I don't even plan to use one for street driving. For show purposes an original can be put back in place but you sure don't want an original to freeze up. . .
    They seem to have the correct part here: http://classicgarage.com/po91912kostd.html
    My car still has the original one and it seems fine...why would one freeze upM Wouldn't a failure typically just end up being loss of damping?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Manuel and every one else, Thanks a million. It is amazing the collected wealth of info on this site.
    Joe
    1966 911 #302694
  1. Steering Damper for ‘66
    By 19-911-65 in forum General Info
    Last Post: 02-04-2018, 07:27 AM
  2. Steering damper bushings
    By merbesfield in forum General Info
    Last Post: 07-03-2017, 06:19 AM
  3. Steering Damper
    By Brad Davis in forum Technical Info
    Last Post: 12-02-2008, 04:38 PM
  4. Steering Damper
    By Brett_Classique in forum For Sale: 911 Parts
    Last Post: 07-01-2007, 04:41 AM
  5. NOS Early koni steering damper
    By glaverbel911 in forum For Sale: 911 Parts
    Last Post: 12-03-2006, 08:56 PM
