Results 1 to 10 of 11
Thread: Road trip questions
    Road trip questions
    My son and I are leaving California Sunday afternoon on a little Route 66 odyssey. I have a couple of questions:
    - the car has been recently painted. Should I put a bra on it or just wax?
    - any thing out of the ordinary you would bring? The MFI belt is new, but I do have an extra. I have a complete tool kit - what am I missing?
    Any advice would be appreciated.
    TY
    Jan 2003
    NW Indiana
    How long is your trip going to be? By complete tool kit, do you mean the Factory tool kit or your own tools? Well I can get your list started.
    -Flashlight and spare batteries
    -Several quarts of oil and a funnel
    -New fan belt
    -Spare cap and rotor
    -Spare coil
    -Extra CD box
    -Spark plugs
    -Clutch cable
    -Fuel pump and filter
    -Fuses
    -Extra headlight, turn signal, brake light bulbs
    -A real jack (944 Aluminum jack works great)
    -Spare wheel barrings
    -Good length of new fuel hose
    -Jumper cables
    No bra ever. Have fun!
    Brian
    '71T
    R Gruppe #299
    make sure that new mfi belt has a few miles on it. they can need 2nd adj. after installation from stretch albeit unlikely if installed to specs
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    In addition to what Brian said, duct tape. Credit Card. Upgrade your AAA card (need one year membership on the books in order to upgrade). Perhaps some sort of flare/triangle in case you are stuck by the roadside.
    '72T Coupe - Sepia Brown
    Aug 2006
    Chicago area
    What Brian and Karl said. Hopefully you won't need any of it. Be sure to assemble your own tool kit also. No bra...
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    I would add some JB-Weld 5 min. Epoxy...
    Just a couple of little tubes in a small zip-lock might bail you out. Oh, in that same zip-lock add some rubber gloves, a few cardboard squares, and a couple of popsicle sticks .....
    This little bag of stuff has come in handy for me more then once........
    Cheers
    Aug 2006
    Sonoma, CA
    I don't know your ignition system, if it's something modern, I'm off base but....
    points?
    condenser?
    distributor cap?
    rotor?
    a few feet of plug wire with spare ends to make iup a spare line?
    fuel filter?
    fuses?
    etc.
    One may not find a lot of these pieces on highway 66, once beyond San Bernadino.
    have a great advenure!
    johnt
    Thanks for the good advice.
    The engine has about 5K miles on in; professional rebuilt. The ignition is stock points/cdi.
    Heading out on some lonely stretches of Route 66/I40. I have the upgraded AAA, but who know if there will be cell service etc on some of those back roads. We leave Sunday afternoon for Laughlin via Amboy etc, then up early for Oatman/Kingman/Flagstaff and the Grand Canyon. Perhaps one more day eastbound (Santa Fe?), then I40 back to LA. My son is 14 - I don't know how much longer he'll want to do this sort of thing...
    Wish me luck - I hope these 911's are as stout as they say they are!
    Since you'll be in some remote areas I would bring an electric air pump + a tire plug kit.
    Sounds like a great trip - your son will never forget the experience
    Aug 2006
    Sonoma, CA
    The laws oif probability which are too often true on my road trips and race weekends say that, "If you have a spare, the original won't break." So either take one of everything, or leave behind thos parts which you believe you can scrounge and you like to replace. Have a great trip!
    johnt
  1. Road Trip Essentials?
    By TheBen in forum General Info
    Last Post: 09-23-2013, 11:59 AM
  2. Vintage road trip
    By 911quest in forum Off Topic
    Last Post: 01-12-2011, 05:38 AM
  3. Crazy road trip
    Last Post: 11-16-2007, 08:09 PM
  4. Road trip anyone?
    By 911pcars in forum Off Topic
    Last Post: 02-17-2007, 05:40 PM
  5. quickie road trip...
    By Chuck Miller in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 03-29-2005, 04:22 PM
