Results 1 to 7 of 7
Thread: What year is this fan shroud for?
    For a while I have this red fan shroud hanging to my wall and I actually don't know what year it's for.
    It looks to be carburetor engine w/ a duct for the oil cooler.
    I appreciate your thoughts.
    Richard
    Late and likely a 3.2 Carrera. 1st ones had no external oil cooler ducting. Second ones had a duct that was riveted* on. This one make access to the oil cooler easier with a short duct.
    *"2nd generation" http://www.early911sregistry.org/for...38&postcount=6
    Damon at Series 900 taught me anything I know about these but I'm a slow learner so what I just told you could be total BS.
    Tom
    Early S Registry #235
    rgruppe #111
    Thanks Tom.
    Is it correct that this style could be than considered 3rd ones?
    1st one's .. no duct
    2nd one's .. riveted duct
    3rd one's .. short duct
    Richard
    It is a late SC shroud. The plug wires left marks on the top or the shroud. Carrera had wire holder over fan housing and wouldn't leave marks. Carrera shrouds are also black. It also has large holes for A/C mounting washers that were not present on early SC. Gordon
    I have one of these also with injector clearance and plan to use it on my 2.4 S MFI hotrod,any reason to avoid using it? Steve
    The SC shroud works great for MFI engines. Just cut Injector cutouts that you can see in the fiberglass and the hole for idle adjustment and you are good to go. I use a die grinder with a small carbide bit to cut holes. Gordon
    May 2006
    CT
    The red shroud pictured is a 3.0 SC shroud. The later 3.2 shrouds were black.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  1. MY=Mid-Year MY= Model Year
    By mfitton in forum General Info
    Last Post: 01-03-2013, 12:18 PM
  2. Build Year vs Titled Year - Serial Numbers
    By luke-44 in forum General Info
    Last Post: 04-12-2012, 05:14 PM
  3. FS Red Fan Shroud
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-08-2012, 01:40 AM
  4. FS: MFI Shroud
    Last Post: 02-02-2009, 12:35 PM
  5. WTB Red shroud for 2.4S
    By Soterik in forum For Sale: 911 Parts
    Last Post: 07-11-2005, 06:26 PM
