Results 1 to 10 of 17
Thread: SWB Horn Relay Picture
    Does anyone have a good picture of the black Wehrle horn relay from a SWB 911? I am looking for a straight on shot of the writing on the side. Trying to get a rubber stamp made so I can restore my relay. Any help would be great!
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    I'll get you a better one if you need. . . if I can borrow the stamp!
    I believe that the horn relay is down near the battery. Their black covers tend to get corroded, hence the need for the stamp.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Dec 2006
    Las Cruces, New Mexico
    Quote Originally Posted by Neil '67 911S View Post
    You are correct, on a 67 at least it is mounted in front of battery directly above the windshield washer pump. I tried to get a pic but no go the text is on the top of the relay and SMALL. I will give it another try this PM.
    Early 911S member #166
    Aug 2007
    Phila Pa. area
    horn relay
    is this the one
    Mike
    Brad
    Here is the graphic for your stamp
    Manuel
    Thanks Guys!! Great help. I found this relay in a 68 911. Any idea when the marking changed? Possibly just a different batch from Wehrle back in the day? Manuel, thanks for the PDF it is very sharp! Much better than what I created over the weekend.
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Picture of relay.
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Hi Guys,
    Here is yet one more variation. I guess at this point you can pick whichever you like the best considering both examples I found came from 68 911's.
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Take your pick
    Font: 1451 Mittelschrift Alternate
    Resized to a correct relay
  1. Location of SWB horn relay
    By Neil '67 911S in forum Technical Info
    Last Post: 07-04-2013, 06:14 PM
  2. WTB 66 horn relay
    By oscillon in forum For Sale: 911 Parts
    Last Post: 02-13-2011, 11:18 AM
  3. Location of horn relay on a 70T?
    By ulrichd in forum Technical Info
    Last Post: 12-03-2007, 08:55 PM
  4. Horn relay location?
    By Cornpanzer in forum Technical Info
    Last Post: 03-27-2004, 02:51 PM
  5. picture of 73 horn installation?
    By TRE Cup in forum Technical Info
    Last Post: 10-11-2003, 09:47 AM
Tags for this Thread
