Let's not forget the linkage, rods, gaskets and spares that were in the bottom of the box!
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Does anybody know if it is feasible to zinc coat the crossover tube without removing the fuel lines?
Would I be better served just replacing the lines due to age, even if they've never been used? If so, what is the story with the crimped connectors? How is this handled?
Thanks.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Interesting factoid about these carbs and the points in my original post around rebushing/o-ringing. From 356 Carburetor Rescue. My question to them:
The response from Candace, as Jim wasn't in the office:Originally Posted by kenikh
Originally Posted by 356 Carburetor Rescue
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
I think the acid used in the cad plating process will eat away the cloth covering. The rubber will be intact, but the surface will be chalky/brittle.
Kenikh, try Autosportengineering.com
Ed, after we install these if we run into any running issues, I am going to pick your brain a bit regarding the Solex mod you described at Laguna Seca, regarding soldering the emulsion tubes. Sounded intriguing, but didn't fully absorb it.
BTW, I also added a link in the first post to an excerpt that includes all factory instructions for the Solex carbs.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Ever seen one of these? NOS air cleaner for a Solex car. To bad the chrome picked up so much rust over the years in storage...
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Just me, but I would not be using 30+ year old German rubber fuel lines on anything,.... Such things have not been the bastions of longevity.
I would remove the rubber lines, clean them all out, replate with clear zinc and have new rubber lines swedged back on.
Nice writeup on these carbs, pal. We have one of these engines here undergoing rebuild & restoration and will be running this on the dyno when its all ready. Should be interesting.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
Thanks, Steve! Sorry I didn't stay true to coming by when I was in Portland last weekend. Too much family activity going on to be able to get away, so I'll just ship the cylinders down.
On to the next question/quest regarding the refit of my Solex carbs. They are now poised to be dropped into my car, but with a few minor parts related snags:
It looks like we need approximately 12-14 crimp fittings, as there were only 4 in the parts that came carbs, as well as other little parts. The crimp ends are the least critical, as we can use hose clamps or other crimp ends, but it just won’t have the look. The other stuff are progress blockers.
Does anyone know of a source for the following or have some spares?
- R & L Drop link from cross bar to carbs (70 below)
- Pivot ball on R side carb body bracket for cross bar (72 below)
- Fuel pump plastic base and base gaskets (2 and 3 below)
- Crimp collars (24 below)
- Bell Crank on Lt. intake manifold for throttle linkage (61 below, I think. Could it be the same as Webers?)
356 Carburetor Rescue didn't have any and I am pretty sure I cleared Gary Emory out of everything Solex related he had left. Ed Fall might have the pump gasket, but haven't hear back yet.
All help/guidance is appreciated.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
