Results 1 to 9 of 9
Thread: 2.8 in a 2.2
    Nov 2003
    Santa Monica CA
    Cool 2.8 in a 2.2
    Anybody have a idea if I could make a 2.8 250hp engine work in a 1970 or 71 car? Could the tranny be modified to take the power? Or should I install this engine in a 2.4 car only. Regards Chris Early S reg#205
    IVS has a 2.8 in his 69 with a 901.
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    RSwannabe has a 2.8SS w/ 901 in his '69.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hi Chris,
    Nothing wrong with fitting a motor like that in a 70/71. My own car is a 71 with a SS 3.2 with almost 300 bhp, running narrow body but with later 915 box.
    It normally runs 6 and 7 inch (7Rs on the rear) but on the track with its track wheels/tires its lots of fun.
    The next car we have in mind is also a 2.8 built around a 66mm crank and that is destined for a race prepped 72 car.
    What spec were you thinking?
    Alan
    Nov 2003
    Santa Monica CA
    2.8 in a 2.2
    Thanks Alan-- I now have a 1970 911S 2.2 which I love and plan on leaving alone. But want to build a sports purpose hot rod 911. Being a member of the Aluminum Lug Nut Club, I am keen of weight saving measures even for the street. With high horsepower in mind I just took for granted I would be putting this 250 hp engine in a 72 or 73 car with the 915 tranny. But the added weight of the 915 and the notchy character of shifting--might not make me happy. As far as the engine spec; so far: 7R case 70.4 crank, still not sure to go MFI or PMO 40 or 46mm. Leaning toward carbs for weight and sport exhaust. Any Ideas for cams? Already have Mahle 92mm P&C modern style. Twin plug 10.5 : 1 ratio. Would like to safely go to 7500 or 7700 rpm ,so mabe some custom valve springs and light connecting rods. the base engine is a long block 73.5 CIS 911T engine. Regards Chris Early S Reg.#205
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    Quote Originally Posted by raspy2point2 View Post
    But want to build a sports purpose hot rod 911 ...... Being a member of the Aluminum Lug Nut Club, I am keen of weight saving measures even for the street ........ putting this 250 hp engine in a 72 or 73 car with the 915 tranny ...... But the added weight of the 915 and the notchy character of shifting--might not make me happy.
    Chris, i think that putting in a 2.8 will give you more power than you will probably need, and that you will be happy. I would not worry about added 915 weight. With such an engine, I don't think it will be an issue. As for notchy shifting, if you are putting in a good-as-new (properly rebuilt) 915, i think you will be surprised as to how well it shifts. The notchy comes after wear and abuse. Care needs to be taken as it is not a japanese box, but you can wevo-ize it to such an extent that notchiness will not be a factor.
    Best of luck with your choices ... sounds like a cool project.
    Karl.
    '72T Coupe - Sepia Brown
    As Kenik mentions above, I have a 2.8SS in my '69 911. I run it through a 901 tranny and would not have it any other way. I much prefer the 901 tranny to the 915 for shift pattern and feel. No question a 915 will be more durable, but after after almost 10,000 miles of hard driving with my 250 plus HP motor I have not had a single issue with my 901 tranny being able to handle it. Just remember not to stomp on the throttle
    in first gear and the 901 should be fine.
    Brooke
    1969 911 ST w/ 2.8SS
    1973 911 RS tribute with 3.3 turbo
    1970 914-6 w/ 2.2S (sold)
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    Jan 2003
    UK
    I also had a 1970 911T with a 2.8 twin-plug motor (~255bhp) mated to the original 911 dogleg gearbox - no problems.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Dec 2006
    Las Cruces, New Mexico
    If the 911 T/A is in good shape you won't have a problem with stomping the throttle in first gear. Drag race ' rev and drop the clutch' starts will kill it though.
    Early 911S member #166
