Thread: manifolds question
    1973 911 # 58 Francois Duval's Avatar
    Dec 2003
    Montreal , Canada
    manifolds question
    Hi, I had my 911 T manifolds machined yesterday to the S specs of 36mm to match my engine`s output.
    now the finish inside the manifold is kind of rough,,,,,,,,, not as smooth as it was before the machining.... do this have an impact on performance
    will this create turbulence on the air being sucked into the engine ?
    any experts out there ? thanks
    Francois
    My understanding is that you want a rough finish on the intake side to keep the fuel air mixture in a bit of turbulence and prevent the fuel from creating droplets.
    AM
    Hi,
    In case it helps, when we machine throttle stacks or manifolds the finish is as original. For example here are some mag MFI stacks finished machining today. These were enlarged to 50mm top to 42mm bottom tapered bore, not an easy task.
    HTH
    Alan
    Jun 2009
    Cape Vincent, NY
    The rough finish is perfect. It "shreds" the air, creating turbulence that keeps the fuel atomized well. Smooth finish is good for the combustion chamber and exhaust port.
    That is some nice machining on those tapers! that must have been a PITA job!
    1968 911S 30K miles
    2006 Saturn Ion DD
    1988 Beretta GT
    1981 5-Ton Chevy stake-bed
    Air goes in and out, blood goes round and round, any variation of this is a bad thing.
    Feb 2005
    Montreal, Canada
    Salut Francois,
    I also heard that rough finish is fine on the intake to get good air/fuel mixture, but the combustion chamber and exhaust should be polished.
    Who machined them for you in Quebec ? Does he do porting on heads ?
    Jean-David (Candiac)
    Dec 2003
    Montreal , Canada
    manifolds
    Thanks for all your input guys, its really appreciated. I take it that
    I will keep the rough finish and it should be fine.
    The company who did the machining is called DC Usinage here in Joliette.
    Its a small business that does many different tasks I heard.
    They kept the shop open for me late at night to do my job, it took them about 1.5 hour to do it. real nice job.
    FRancois
  1. Replies: 7
    Last Post: 05-06-2012, 02:36 PM
  2. Replies: 1
    Last Post: 10-04-2011, 08:10 AM
  3. WTB: 67S manifolds
    By ajwans in forum For Sale: 911 Parts
    Last Post: 05-16-2008, 08:45 AM
  4. Factory "TALL" manifolds vs PMO manifolds
    By RPMClassic in forum For Sale: 911 Parts
    Last Post: 01-26-2008, 09:14 AM
