Thread: S caliper thread
    Atlanta, GA
    S caliper thread
    Help me find the thread on one of the forums where someone was selling a complete conversion for aluminum S type brake calipers. I think it was a UK forum/seller. The kit he put together had ATE calipers with a spacer block he made up, if I remember correctly, to widen the caliper to fit over the vented rotors. He also had the rotors and other parts.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Oct 2008
    Burford, ON, Canada
    http://www.early911sregistry.org/for...ad.php?t=29149
    This has nothing to do with aluminum S calipers though.
    What is it that you are trying to do?
    Atlanta, GA
    That's the thread. So as mention, it is not aluminum calipers. Would this be considered a good set up tho as an improvement for a 68 912? I was going to send off my calipers for rebuild to PMB Performance, but this is comparably priced I think.
    Mark Erbesfield
    1957 356A #58648
    Thumbs up
    I support Eric at PMB Performance. He knows his brakes and can help you get the perfect setup for your needs. He also does amazing restoration work.
    Oct 2008
    Burford, ON, Canada
    For a 1968 you need a combination of parts to go to vented brakes. I was working up the parts required for a 1966 which should be pretty much the same:
    PMB's Brembo aluminum front caliper kit, front hub for the vented rotor plus new bearings and seals, front vented rotors. Not certain, but a different spacer may be required to install the front hub. Can someone please confirm one way or the other.
    Alan.uk's rear calipers and modified vented rear rotors to suit.
    Porterfield AP174 R4-S pad set front & rear.
    Not an inexpensive solution, but one that matches the 911S brake system, and perhaps one-ups it. Also it does not require changes to the front or rear suspension so that a return to stock is quick and easy.
    Link to the brembo front caliper's. I have a set, and they are very nice.
    http://www.early911sregistry.org/for...d.php?p=199125
  1. Replies: 1
  2. Vintage 911S Caliper Restoration Thread
    By Neunelfer in forum Technical Info
    Last Post: 03-03-2015, 01:58 AM
  3. WTT: 908 Caliper
    By HaraldD in forum Free, Trades, and Swaps
    Last Post: 12-08-2013, 04:19 PM
  4. Caliper Fit
    By chicagobreezz in forum Technical Info
    Last Post: 04-01-2009, 11:29 AM
  5. L-Caliper Identification Thread
    Last Post: 05-03-2008, 04:35 PM
