Results 1 to 2 of 2
Thread: 46mm Webers for 68S Historic Racer
    I just finished up a Level 3 remanufacturing and restoration effort for the 46mm Webers currently on Edward Mahle's 1968 911S Sport Kit 2 equiped historic racer which is maintained by Ben Kirchner @ Retro Sport in Berkely, CA. The reason for this post is to alert those in need of progression circuit modification for your Webers that I can help. (I also convert 40's into 46's using my process or into 42's if these are more to your liking.)
    The carbs came to me with a Jerry Woods modification of the progression circuit which was essentialy a little pill insert into the well under the progression port plug, the pill having a vertical slit to meter out fuel, progressively. The customer desired to revert to the 3-hole progression which is what I provided using my technique of converting 40's into 46's. I also removed studs and lead plugs before refinishing everything. Check out the photos.
    Cheers,
    Paul Abbott
    www.PerformanceOriented.com
    Paul Abbott
    Early S Member #18
    Weber service specialist
    info@PerformanceOriented.com
    530.520.5816
    I must say, they are a work of art!
    Really nice job on the 46's
  1. WTB: 46mm Webers
    By 9146racing in forum For Sale: 911 Parts
    Last Post: 03-01-2013, 07:10 PM
  2. 46mm Webers Wanted
    By eronbo in forum For Sale: 911 Parts
    Last Post: 06-22-2012, 05:13 PM
  3. 46mm Webers
    By eronbo in forum Technical Info
    Last Post: 06-17-2012, 11:08 PM
  4. Rebuild my 46mm webers or switch to EFI?
    By blucille in forum Technical Info
    Last Post: 12-19-2011, 03:20 PM
  5. WTB: 46mm Webers
    By LeonardZ in forum For Sale: 911 Parts
    Last Post: 08-28-2009, 03:37 PM
