Thread: Fuel tank return fitting - NLA
    This picture shows the fuel tank return fitting, center connection on a 1970 tank. This has obviously seen better days, and is NLA. Does anyone have any suggestion for replacing this? Is there a comparable later part? Maybe I should just go directly to a WTB post.
    I haven't ruled out replacing the tank entirely, and I assume this part would be included. The tank's pretty rusty inside. But I'd like to try to clean and seal, if I can get the necessary parts replaced.
    Mike
    Jun 2009
    Cape Vincent, NY
    Not sure about a later part that would fit, but you could try a hydraulic hose shop. Should have all the fittings, and maybe cheaper than Porsche part.
    1968 911S 30K miles
    2006 Saturn Ion DD
    1988 Beretta GT
    1981 5-Ton Chevy stake-bed
    Air goes in and out, blood goes round and round, any variation of this is a bad thing.
    Aug 2007
    Phila Pa. area
    fitting
    Its just a banjo fitting. Drill it out, tap it , put in a nipple.
    Mike
    Hi Mike,
    If you can send me the inside diameter of the banjo fitting I can get both the banjo and the hollow bolt from Cohline.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Aug 2007
    Phila Pa. area
    measure
    can't you just measure your tank opening or fitting?
    Quote Originally Posted by Brad Davis View Post
    Hi Mike,
    Best regards,
    Brad
    Mike
    Thanks guys for the suggestions. Brad, I appreciate the offer, but I'm going to give Mike's suggestion to drill, tap, and fit something of the same diameter a try. Either that or go the new tank route. After removing my level sender and getting a glimpse inside the tank this seems like the best way to go. Yeeoww, it is nasty in there! The tank had sat empty for several years, and is severely rusted inside. It might be treatable, but it would just end up being one of those things that nags at me, making me wonder when it will cause a problem. I don't need any more such things. There, I've talked myself into it.
    Cheers,
    Mike
  1. WTB: Fuel Banjo Fitting
    By drwhosc in forum For Sale: 911 Parts
    Last Post: 03-17-2014, 07:47 AM
  2. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  3. MFI Return Fuel Tee
    By 50/50 in forum Technical Info
    Last Post: 04-21-2012, 10:31 AM
  4. FS: NOS Fuel tank fitting with sock/filter
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 07-08-2009, 09:35 AM
  5. Fitting a new MFI fuel pump!
    By Alan.uk in forum Technical Info
    Last Post: 01-26-2009, 11:44 AM
